July 24, 2009, 05:02 |
why heating water have no water vapour?
peterlee
Rep Power: 17 |
Hi, everyone!
I am trying to set up water boiling model with the help of "boiling-water.ccl" installed in the CFX directory. And I have modified many option which are approprite for heat transfer, momentum transfer, and mass transfer, in addition, I introduced "Musig Fluid model" However, when the water tempreture rise up to 373k, there have no water vapour which should be produced near the heated wall !!! So, may I know your finer idea in sovling the problem? thank you peter |
July 24, 2009, 09:11 |
Andrew
Rep Power: 18 |
I know in Fluent when I did something similar to this I had to set it up for two phase flow. Have you done this? Fluent has/had a good tutorial for boiling water.
July 24, 2009, 23:58 |
peterlee
Rep Power: 17 |
Fluent can't simulate the superheated boiling well, and I have seen a movie file showing boiling water made by CFX, so I believe CFX can do it perfectly.
July 25, 2009, 00:09 |
peterlee
Rep Power: 17 |
With the help of "boiling-water.ccl" which use water and water vapour form two phase flow in the installed directory of CFX, in addition, I chose other models for MOM transfer, heat transfer, and mass transfer, phase change tem. is 373k. But there have no water vapour near the heated wall !
why heating water have no water vapour? | peterlee | Main CFD Forum | 0 | July 24, 2009 04:09 |
condensation of water vapour at room walls | Felix | FLUENT | 0 | September 14, 2007 12:03 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 08:15 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 08:10 |
