Rep Power: 16 ![]() |
I am interested in a time accurate solution for a multiphase (air/water) problem, whereby it is important that the courant number fall below 1. This is easy enough to set up in CFX, however I have an expression for the flow velocity which is dependent on the value of the current timestep.
Sooo...My question is: What CEL expression (if any) can I use to call the current timestep into my equation, since it will be changing based on the adaptability criteria. Any help help you can provide would be a huge help ![]() |
Apollogies, I realize i should have put this in the CFX forum.
how to map resultd from cfx to ansys? | ritesh | CFX | 2 | June 1, 2011 07:52 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 04:47 |
ANSYS to acquire CFX | Fred | FLUENT | 0 | February 18, 2003 21:04 |
ANSYS to acquire CFX | Fred | Siemens | 0 | February 18, 2003 21:03 |
