How to calculate dynamic viscosity for sea water?
Old   October 4, 2003, 14:07
Default How to calculate dynamic viscosity for sea water?
James L.
Does anyone know how to calculate the dynamic viscosity for sea water for a given sea water density, temperature and pressure?
Old   October 7, 2003, 09:08
Default Re: How to calculate dynamic viscosity for sea wat
James L.
Nobody knows how to calculate viscosity?
Old   October 7, 2003, 09:14
BeachComber
Viscosity of sea water is more a function of temperature and salinity. Don't know if there are equations for this, but you can find tables at: http://www.unisense.com/support/pdf/gas_tables.pdf
Old   October 7, 2003, 11:51
James L.
Thank you for that!
According to the notes for these tables, they've used some unknown formulas to calculate this: "NOTE! Use tables 1 and 2 for salinities between 0 and 40 ‰ and temperatures between 0 and 40 °C. The formulas used to calculate these tables are only valid in these intervals. The formula used in table 3 is less precise in these intervals, but is a good approximation at higher salinities and temperatures."
I'd guess that both temperature and salinity also is a function of pressure/depth like for density, but how do I calculate this with a good approximation?
Old   October 7, 2003, 13:53
BeachComber
You sure like to ask the difficult questions, don't you. Anyway, Cal State, Northridge has just such info that you are seeking. Try: http://www.csun.edu/~sd51881/ocean_env.pdf
This document contains all kinds of good info - but you would need to contact them to find out where they got it from as references are not included. It shows contour plots of salinity throughout the oceans as well as gives some typical salinity and temperature profiles vs. depth.
Good luck!!
Old   October 7, 2003, 19:05
James L.
Thank you, this was very useful!
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Dynamic Viscosity output kakarot9999 FLUENT 1 September 14, 2011 11:01
Problems with BCs in muliphase flow with water falling from a reservoir Paul_l FLUENT 2 March 11, 2011 05:59
Liquid water, gaseous water and another gas Andy FLUENT 1 May 22, 2006 09:51
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
