External,incompressible flow boundary condition?
Old   October 1, 2003, 01:00
Default External,incompressible flow boundary condition?
John
Hi. I'm currently working on a CFD project.
I need to use Fluent 6 to obtain aerodynamic result for external incompressible flow over a object.
I heard from my someone that since it is external flow over a object. I have to use the Pressure Far Field boundary condition. However, I realise that Pressure Far Field is only for compressible ideal gas.
May I ask the question whether I can use velocity inlet boundary condition to define external flow around the object?? I can't use the Pressure Far Field boundary condition in this case right???
What type of turbulence model is suitable for low speed, incompressible, external flow around the object???
I have tried to iterate to obtain result but sometimes I obtain such error and the iteration terminate. May I know what went wrong?? Thanks.The statement printed when I receive the errors are as follows. Many Thanks
Error:>(greater-than):invalid argument [2]:
wrongtype [not a number] Error object:ran0x7ffffe00 Error:Cortex received a fatal signal (BUS ERROR) Error Object: ( )
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Boundary condition for exhaut flow with imposed mass flow stephane FLUENT 1 November 24, 2011 03:04
Volume of Flow Rate (VFR) boundary condition therockyy FLOW-3D 0 May 23, 2011 15:19
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
How can apply mass flow rate boundary condition? Sima Phoenics 1 December 1, 2007 19:55
