gmsh usage - how to generate patterns?
Old   July 7, 2009, 01:23
Default gmsh usage - how to generate patterns?
Can Ozcan
canciger is on a distinguished road
Send a message via Skype™ to canciger
Hi All;
This is my first message. I am working with commercial tools every day and night. I would like to give opensource a try, to see the capabilities.
I am not sure if this is the right thread to post. Please advise otherwise.
I am experimenting with gmsh, to generate some simple mesh. I kind of liked the fact that it has scripting option. However I am stuck at simple operations. I would like to have a symmetry copy of a half sphere, which is shown on the left(structured):
However not only the shape of the surfaces but also the mesh does not come out as expected. Any help/ideas are appreciated.
I am using the following code:
* Gmsh tutorial 1
* Variables, elementary entities (points, lines, surfaces), physical
* entities (points, lines, surfaces)
// The simplest construction in Gmsh's scripting language is the
// `affectation'. The following command defines a new variable `lc':
lc = 0.009;
Point(1) = {0, 0, 0, lc};
Point(2) = {.1, 0, 0, lc} ;
Point(3) = {.15, .125, 0, lc} ;
Point(4) = {.1, .25, 0, lc} ;
Point(5) = {0, .25, 0, lc};
Line(1) = {1,2} ;
Spline(2) = {2,3,4} ;
Line(3) = {4,5} ;
Line(4) = {5,1} ;
Line Loop(5) = {4,1,2,3} ;
//Plane Surface(6) = {5} ;
Physical Point(1) = {1,2} ;
MyLine = 99;
Physical Line(MyLine) = {1,2,4} ;
Physical Surface("My fancy surface label") = {6} ;
block_thickness = 0.3;
// Create surface
Plane Surface(6) = {5};
// Put 20 points with a refinement toward the extremities on curve 2
Transfinite Line{1} = 5;// Using Bump 0.05;
// Put 20 points total on combination of curves l1, l2 and l3
Transfinite Line{2} = 10;
Transfinite Line{3} = 5;
Transfinite Line{4} = 10;
// Put 30 points following a geometric progression on curve 1
// (reversed) and on curve 3
//Transfinite Line{-1,3} = 30 Using Progression 1.2;
// Define the Surface as transfinite, by specifying the four corners
// of the transfinite interpolation
Transfinite Surface{6} = {1,2,4,5};
// (Note that the list on the right hand side refers to points, not
// curves. When the surface has only 3 or 4 points on its boundary the
// list can be omitted. The way triangles are generated can be
// controlled by appending "Left", "Right" or "Alternate" after the
// list.)
// Recombine the triangles into quads
Recombine Surface{6};
// Apply an elliptic smoother to the grid
Mesh.Smoothing = 100;
//Extrude {0,0,block_thickness} {
// Surface{6}; Layers{ {4,2}, {0.5,1.0}};Recombine;
Extrude {{0, 1, 0}, {0, 0, 0}, 1.0*Pi} {
Surface{6}; Layers{ {4,4}, {0.5,1.0}};Recombine;}
//Extrude {{0, 1, 0}, {0, 0, 0}, 1.0*Pi} {
// Surface{117}; Layers{ {2,4}, {0.5,1.0}};Recombine;}
//Symmetry {0, 0, 1, 0} {
// Duplicata{Volume{1};}
Symmetry {0, 0, 1, -.001} {
Duplicata{Surface{116, 113, 6, 117, 109};}
Or alternatively: could you recommend some other/better open source, scriptable meshing tool?
Regards...
canciger is offline   Reply With Quote
gmsh, mesh pattern, symmetry
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] How does Gmsh deal with overlap boundaries? yuhai OpenFOAM Meshing & Mesh Conversion 1 April 24, 2009 14:34
Generate a small boundary region near the wall sarah_ron2002 FLUENT 3 February 27, 2008 12:17
How to generate a atmospheric boundary layer Morten Andersen CFX 3 January 16, 2007 07:48
how to generate postscript file? leo Siemens 6 May 28, 2003 00:38
