Temperature profiles for rectangular slab
Old   June 23, 2009, 06:50
Default Temperature profiles for rectangular slab
Himaloi Amo
jothiek is on a distinguished road
I've been assigned a problem to find the temperature profiles for a rectangular slab of 150 mm X 100 mm dimensions for a material of steel. Temperatures at the left wall/border is 400C, at the top is 400C, right is 400C and at the bottom is 300C. I am also to make a plot of the temperature profile along the centerline.
I'm guessing it's a very simple problem. But since I'm quite new to the whole thing, I just don't know how to start. Can someone please help? I'm using FLUENT and GAMBIT. Thanx in advance.
jothiek is offline   Reply With Quote
Old   June 23, 2009, 11:26
Cool
Ahmed
Ahmed is on a distinguished road
your bc's are of the Dirichelet type, why cannot you pick a pencil and a sheet of paper and develop a closed form mathematical solution, if you cannot do that, look the book by Carslaw, the book by Necati or Arpaci for the solution.
If you still want to use FLUENT, then draw a rectangle in Gambit, mesh it and export the mesh to the solver. Run the solver without activating the momentum and continuity equations, just the energy equation. Does that sound simple for you?
Ahmed is offline   Reply With Quote
Old   June 23, 2009, 15:47
Default Thank you for this
Himaloi Amo
...Run the solver without activating the momentum and continuity equations, just the energy equation...
I'll try doing this. Thanks.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Total temperature and static temperature rogbrito CFX 1 June 21, 2009 19:37
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 18:31
High temperature methane+air Peter FLUENT 5 January 26, 2009 19:04
Educational example for temperature profiles A Buang Main CFD Forum 0 September 10, 2008 12:31
