Random vector
Old   September 15, 2003, 05:53
Default Random vector
beggin
My problem is: let there is a plane in a 3D space: a*x+b*y+c*z+d=0 and certain point on it (x0,y0,z0). How to find an unit vector (rx,ry,rz) from this point but in random direction in one of hemispheres (so called diffuse scattering on a plane).
Thank you.
Old   September 15, 2003, 05:59
Default Re: Random vector
Sergei Chernyshenko
Generate a random unit vector of arbitrary direction. Throw it away if it points into the wrong semisphere and generate another.
Sergei
Old   September 15, 2003, 06:45
beggin
Yes, this is an original and simple variant but 50 % of whole work is in vain. Probably there is more efficient ways?
Old   September 15, 2003, 08:11
Sergei Chernyshenko
Then take the mirror image if the vector is pointing in the wrong semisphere. However, random number generation is cheap anyway. Are you sure that CPU time is not consumed by something else?
Sergei.
Old   September 15, 2003, 11:31
beggin
Many thanks! May be don't take a mirror image but simply change a sign before "bad" vector?
Old   September 15, 2003, 11:34
Sergei Chernyshenko
Yes, it is even better.
Old   September 16, 2003, 03:34
Rami
If you wish to do it rigorousy, then you should proceed as follows. Define the the polar angle, theta, as the angle from the normal to the surface in the desired direction. Define the azimuthal angle, phi, as the angle from a predifined vector on the plane (which may be chosen arbitrarily once). It may be shown (by spherical geometry considerations)that the diffuse distribution is obtained by uniform distribution of phi and (sin(theta))^2. The piece of code to find these angles is given below (with Numerical Recipees random number generator).
c ..theta: angle to normal
tht = asin(sqrt(ran1(iseed)))
c ..phi: azimuthal angle
phi = twopi * ran1(iseed)
c ..direction cosines
pno = cos(tht)
pt1 = sin(tht) * cos(phi)
pt2 = sin(tht) * sin(phi)
Now you should transform the resulting unit vector to any convenient coordinate system, e.g.,
c ..direction
ray(1) = pno*norm(1) + pt1*tan1(1) + pt2*tan2(1)
ray(2) = pno*norm(2) + pt1*tan1(2) + pt2*tan2(2)
ray(3) = pno*norm(3) + pt1*tan1(3) + pt2*tan2(3)
Old   September 17, 2003, 03:59
beggin
Thank you Rami, you give "scientific foundation" but for practical calculation the approach offered by Sergei is probably more faster.
Old   September 17, 2003, 04:36
Rami
I quite agree.
Assign one vector to another - still a field? David* OpenFOAM 3 May 27, 2011 11:47
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 18:24
what is gradient vector? majestywzh FLUENT 0 April 14, 2003 00:57
