Fluent Source Code
Old   June 12, 2009, 15:38
Default Fluent Source Code
Crystal is on a distinguished road
Is it possible to auto-generate the source code for a Fluent simulation done interactively on the GUI?
Thanks.
Crystal is offline   Reply With Quote
Old   June 13, 2009, 13:45
Default Think again about how you phrased that question
Charles
CapSizer is on a distinguished road
I think what you are asking is "Can you record a script file of the problem setup", and the answer to that is yes, you can record a journal file. RTFM, it is explained there.
CapSizer is offline   Reply With Quote
Old   June 15, 2009, 06:30
Default Rephrasing my question
Perhaps my question wasn't phrased clearly enough...no, I wasn't referring to the script file, but to the source code or the programme file in C language that Fluent (and also Gambit) uses to run the simulation process - from the discretization to the boundary condition and material properties setup to the solution process etc... For example, in COMSOL and the MATLAB curve fitting tool, you can generate the m-file (MATLAB source code) that is used to run that particular process. I know we can couple our own UDFs to Fluent, but are we able to see what goes on "behind the scenes" in Fluent itself? Thanks!
Old   June 15, 2009, 06:34
Default You must be joking!
Charles
Nope, and if, unlike most of us, you bothered to read the license agreement you would probably find a paragraph explicitly prohibiting the "uncompiling" or any other form of reverse-engineering of the code.
Old   March 3, 2010, 07:41
Dr Suvash C Saha
Suvash Saha is on a distinguished road
That's why FLUENT called the BLACK BOX...
Suvash Saha is offline   Reply With Quote
Old   March 3, 2010, 21:34
N/A
harishg is on a distinguished road
Fluent is a proprietary software. If you look into opensource codes like OepnFOAM, Elmer etc. , you will have an idea of how things are done in Fluent.
harishg is offline   Reply With Quote
Source Terms in Momentum Balance vidyaraja Main CFD Forum 0 May 25, 2009 16:24
Source Terms in momentum Balance vidyaraja FLUENT 0 May 25, 2009 14:16
search for a code to R/W fluent case/data file zou jianfeng FLUENT 0 November 11, 2008 09:16
Pre & Post-Processor source code !! C. Beghein Main CFD Forum 1 January 30, 2002 09:35
Source term for diffusion equation in FLUENT 4.5 Raja Banerjee FLUENT 1 August 31, 2000 00:00
