Inertial and viscous coefficient for porous media
Old   June 12, 2009, 12:54
Default Inertial and viscous coefficient for porous media
Franz Roman
franzdrs is on a distinguished road
Does somebody know if the C2 and 1/alpha coefficients for the porous media model MUST be positive values? I have found these coefficients using one of the methods described in the Users Guide (Deriving the porous coefficients based on experimental pressure and velocity data) and the C2 coefficient turns to be negative because the quadratic term of the regression equation is negative. In the Users Guide itself, in the example of this method, they get 1/alpha to be negative (-242282). So, does anybody knows if that actually matters? Since FLUENT does not know that my quadratic term was negative so that with the negative sign of my C2 the value turns positive, I dont know what FLUENT will make with that.
Some help anybody?
Franz
franzdrs is offline   Reply With Quote
Old   June 12, 2009, 15:16
Andrew
mettler is on a distinguished road
my permeability and inertia coefficients were both positive I found mine from actual laboratory data tho. I am pretty sure I followed a method described in a paper by Boosma to get the coefficients. Also, there are a lot of papers dealing with research of heat transfer in porous media, and most have values for the permeability and inertia. K, permeability, cannot be negative due to the square root of the value. I can't remember which one is which in Fluent - sorry
mettler is offline   Reply With Quote
Old   June 12, 2009, 16:36
Aroon
vishyaroon is on a distinguished road
I have faced similar problems in the past. However as Mettler mentions these values have to be positive (physically negative values do not make sense). So the common approach we follow to get positive co-efficients is to modify the data points obtained from the lab data that represent the low velocities, within the experimental tolerence limit.
We choose the low velocity points because generally these are the ones that result in the negative values (numerically they affect the x-intercept).
vishyaroon is offline   Reply With Quote
Old   June 13, 2009, 07:27
Franz Roman
yes, I understand that these coefficients should be theoretically positive. However, since these values are empirical, would not be possible that when the regression gives a negative coefficient, then when FLUENT uses them the positive coefficient compensates for the negative one and at the end one has a good result? I guess if I knew how FLUENT works with these values then I could tell, but I dont know that much. Somebody?
Thanks
Old   August 12, 2011, 23:07
Default porous media model
subha_meter's Avatar
Subhasish Mitra
subha_meter is on a distinguished road
FLUENT uses a Darcy-Forchhimer type equation which has a viscous term and an inertial term. The equation looks like
Delta P = E1*Re/Ga + E2*Re&\^2/Ga
where E1 & E2 are Ergun constants - 150 & 1.75 or 180 & 1.8 and many other different combinations are possible depending on system and porous medium.
Re = Reynolds number, Ga = Galileo number
In simpler form, the equation can be written as
or Delta P = v/alpha + 0.5*C*v*|v| (v = velocity, 1/alpha = viscous resistance, C= inertial resistance)
Hope it helps
SM
subha_meter is offline   Reply With Quote
Old   September 14, 2013, 07:13
Exclamation inertial and viscous co-efficients for porous media
Anonymous
dreamlifter747 is on a distinguished road
hello guys ,
I have trouble finding the alpha and beta values for modelling plasma (blood ) flow through a porous media which acts as the filter. All i have is the porosoity report and material properties.
Is it possible to calculate the inertial and viscous co-efficients ?
dreamlifter747 is offline   Reply With Quote
Old   September 16, 2013, 00:33
Andrew
The only was I was able to get the two coefficients was run a physical experiment and measure the pressure drop thru the various porous media I was studying. After knowing the pressure drop you can back calculate the two coefficients.
good luck
Viscous resistance coefficients in porous medium fpingqian FLUENT 50 June 26, 2019 02:55
porous media convergence help Brian FLUENT 6 February 22, 2012 06:44
viscous and internal resistance coefficient in porous media bansal_vikas1 FLUENT 12 October 6, 2010 09:28
Discrete phase modeling on porous media magnounibo FLUENT 0 April 9, 2009 09:18
Defining Viscous and Inertial Resistance Coeff.s sean FLUENT 2 July 12, 2001 06:02
