DNS data of Jimenez et al. for turbulent channel flow @ Ret = 2000
Old   June 9, 2009, 14:07
Default DNS data of Jimenez et al. for turbulent channel flow @ Ret = 2000
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
i'm having some troubles in analysing the spectral data of Jimenez et al. for the turbulent channel flow @ Ret = 2000.
I can't figure out what is the proper scaling of the energy and wave numbers.
Actually, i have fortuitously found the proper scaling for the wave numbers (apart from the dealiasing) but i'm still unable to find the proper scale for the energy.
For proper scale i mean some factor which will convert the energy to the form used in the data of Kim, Moin & Moser for Ret = 180.
Is there someone who already faced the same problem?
Edit
The data are available at:
http://torroja.dmt.upm.es/ftp/channels/data/
Thanks in advance
Last edited by sbaffini; June 9, 2009 at 19:30. Reason: Added link to the turbulent channel flow database
sbaffini is offline   Reply With Quote
Old   July 8, 2013, 09:14
Post
Q. Yang
O.YANG is on a distinguished road
Attached are a fortran code I used to read Jim\'enez's spectra data base and the results for 200 and 2000 cases. It gives a similar result with that in their paper (Juan C. del Alamo and Javier Jimenez (2003) "Spectra of the very large anisotropic scales in turbulent channels", Phys. Fluids Vol. 15 No. 6, pp L41-L44).
I am not quite clear how the author did the non-dimensionalization, but I used (kx+)*(kz+)/utau/utau for it.
O.YANG is offline   Reply With Quote
Old   July 29, 2013, 07:03
sbaffini's Avatar
Paolo Lampitella
Dear Yang,
thank you for the concern. Back in 2009 i was finally able to manage the 1D spectra of Jimenez (which now i jelously preserve as they are not anymore available); in the end, it was just a matter of proper scaling factors, more specifically it was just a Re_tau = 2003 factor.
However, i really appreciate your contribution as i never had the chance to dive in the 2D spectra. Now i can, thanks.
Yacht in Open Channel Flow andreimour FLUENT 1 October 15, 2010 00:54
mulltiple channel flow I.Dotsikas Main CFD Forum 2 September 23, 2010 21:49
LES fully developed channel flow Gem FLUENT 4 May 12, 2005 06:30
Exp. data for transonic flow J. Held Main CFD Forum 4 April 1, 1999 23:21
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 18:23
