How to define size of domain for free surface simulation?
Old   June 8, 2009, 00:56
Unhappy How to define size of domain for free surface simulation?
Sarunya
Sunya is on a distinguished road
This work studies flow behavior of pollen around papaya flower. But I don't know the suitable size of domain to simulate it. The size of domain should be how many time of flower size? Or in the other case like flow around some object, how large the domain should bigger than the object?
Thank you in advance.
Sunya is offline   Reply With Quote
Old   June 8, 2009, 09:58
Ford Prefect's Avatar
Ford Prefect is on a distinguished road
It depends on the flow conditions on your boundaries. You do not state what you are investigating. Is it the transport of pollen to the flower or is it the transport of pollen away from the flower? Assuming that it is the first then you need to have a domain that is large enough so that you capture the wake behind the flower, where some pollen (that missed the flower) might recirculate and impact on the flower in a later stage. What Reynolds number do you have?
"Trying is the first step to failure." - Homer Simpson
Ford Prefect is offline   Reply With Quote
Old   June 9, 2009, 00:33
Sarunya
The pollen flow to the flower. Reynold's number = 900 when wind speed = 1m/s and 21000 when wind speed = 22 m/s (Maximum velocity as possible). Size of flower is about 1.5-5.0 cm.
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 22:13
domain size for 3d external aerodynamics edi FLUENT 3 January 1, 2018 04:33
Domain size change. Paul FLUENT 2 October 11, 2003 17:34
Help on simulation domain Derek Jing Main CFD Forum 3 June 6, 2002 21:21
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
