LES combustion problem
Old   August 28, 2003, 10:52
Default LES combustion problem
Salvador
I am modelling non-premixed turbulent flames using LES. I am systematically obtaining a much smaller jet penetration than experiments or RANS solutions. I even obtained it starting from a "correct" k-e solution. I have tried several combustion models and the problems persist. (it also happens when I test a pure mixing case with a prescribed density distribution in mixture fraction space) I think is related to the relatively coarse grid used that introduced a lot of numerical diffusion. However, some people suggest me that incorrect incoming turbulent BC can be the cause. Any ideas/suggestions around there?
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
Problem with handling LES modeling with dynamic mesh g.akbari OpenFOAM Running, Solving & CFD 0 March 8, 2010 17:18
Combustion Problem Arnab Siemens 2 April 29, 2009 09:13
Problem in solving combustion simulation Ramesh FLUENT 0 June 2, 2006 13:21
Combustion: pool fire problem Jonathan CFX 2 October 27, 2003 12:49
