May 20, 2009, 10:47 |
Best CFD software to model phase change
Ana Catarina Marques
Hello all. I知 really new to CFD.
At the moment I知 trying to figure out which CFD software to go for. I have narrowed it down to CFX, Fluent, Star CD and CF Design. Among those CF Design seems the easiest to learn but I知 not sure it can handle multiphase flow; does anybody have any experience on this? I will be mostly modelling a phase change material with a moving solid/liquid interface. Any advice on the best CFD package for multiphase flow would be much appreciated. Thanks |
May 22, 2009, 10:13 |
Nuno Gomes
Rep Power: 17 |
Hi
Iエm new on CFD but i have seen some interesting work about multiphase flow on Fluent. Regards |
May 25, 2009, 06:40 |
#3 | |
Rep Power: 17 |
In our group we use Fluent and Phoenics. If you are not afraid to write your own subroutines then both software would be fine. If you do not want to write your own subroutines then I can not recommend any of the two for multiphase flow with phase change.
"Trying is the first step to failure." - Homer Simpson |
June 2, 2009, 11:54 |
Rachel Vogl
Rep Power: 17 |
I would say consider OpenFOAM. It has some phase change applications and some others are under development by users.
The big advantage is that you would be able to implement the models you like. The disadvantage is the learning curve. However now there is a GUI for OpenFOAM, which solves a lot of beginner problems, but you have to pay for that. |
June 5, 2009, 10:35 |
Hans Bihs
Rep Power: 18 |
Try Star-CCM+, they are pretty strong for free surface calculatiions, they use VOF. I you prefer the level set method, this code may be right for you: http://wissrech.iam.uni-bonn.de/rese...DGPF/index.htm
June 10, 2009, 07:43 |
#6 | |
Rep Power: 17 |
Try MFIX, it is free, and it was developed for multiphase flows. |
cfdesign, phase change |
Solid/liquid phase change | fabian_roesler | OpenFOAM | 10 | December 24, 2012 06:37 |
Which software can model more than two phase fluid | J.Yang | Main CFD Forum | 8 | September 3, 2002 06:37 |
ASME CFD Symposium - Call for Papers | Chris Kleijn | Main CFD Forum | 0 | September 25, 2001 10:17 |
ASME CFD Symposium | Chris Kleijn | Main CFD Forum | 0 | August 22, 2001 06:41 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 17:25 |
