What is the difference between liquid reactive flow and gas reactive flow?
Old   May 14, 2009, 12:16
Question What is the difference between liquid reactive flow and gas reactive flow?
James Zhong
James is on a distinguished road
Hi All,
I am doing a project on Functionally Graded Materials (FGM). I use a solidification process to generate FGM and find that there is intermetallic compounds in the products. So I think this process involves liquid reactive flow. Now I need to simulate the solidification process with reactive flow.But I found out that almost all of the books and literature deal with gas reactive flow (mostly on combustion). Does anyone know what the difference is between liquid reactive flow and gas reactive flow? How can I transfrom those governing equations for gas reactive flow for use in liquid reactive flow? Does anyone know any books or literature handling liquid reactive flow? Thanks!
James
James is offline   Reply With Quote
Old   May 14, 2009, 17:51
Ford Prefect's Avatar
Ford Prefect is on a distinguished road
Reactive flow in liquids usually involves new phase-formation, whereas gas-reactive flow usually only involves formation of new species in the gas mixture. So assuming that you get some new phase-formation, then the physical data for interfacial properties are usually unknown and there are few (if any) good multiphase methods to deal with reacting flow. If you add solidification to this you have an extremely complex problem.
Fun problem though, so good luck!
Ford Prefect is offline   Reply With Quote
Old   May 14, 2009, 18:21
Default Re: What is the difference between liquid reactive flow and gas reactive flow?
James Zhong
Hi, Ford:
Thank you for your reply! What do you mean by new phase? Suppose we have liquid Ni and Al, if they react to form NiAl, is NiAl the new phase you mentioned? What is the difference between "new phase" and "new species"? Thank you again!
James
Old   May 14, 2009, 19:02
johndorian is on a distinguished road
Originally Posted by James View Post
Hi All,
James
The main difference between reaction in gases and in liquids is the Schmidt number of the flow. Gases have Sc ~ 1, whilst liquids have Sc ~ 700, and this has a significant effect on how chemical species are mixed in the flow. See the following paper - "Scalar mixing and reaction in plane liquid shear layers", P. S. KARASSO M. G. MUNGAL, J. Fluid Mech. (1996), vol. 323, pp. 23-63 for some useful information.
johndorian is offline   Reply With Quote
Old   May 15, 2009, 01:34
James Zhong
Hi,John:
Thank you for your useful information! I will try to get the paper.
James
Old   May 15, 2009, 08:54
Hi, Ford:
James
Species are part of a mixture, connected to a specific phase. For instance, if you model air you will have two major species, O2 and N2 along with a number of smaller ones. The temperature, pressure and partial pressures of each species will give you the properties of the air phase.
Old   May 15, 2009, 13:14
Default Re;What is the difference between liquid reactive flow and gas reactive flow?
James Zhong
Ford,
James
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
gas liquid flow Yuqing Feng CFX 0 May 4, 2004 22:26
CFD of laminar reactive liquid flow Ingo Meisel Main CFD Forum 5 March 12, 2004 05:38
Gas Liquid flow in a packed column Rakib FLUENT 8 June 18, 2002 02:58
liquid and gas flow faouzi FLUENT 3 July 10, 2001 10:52
