Re=300 flow over a sphere
Old   August 14, 2003, 13:31
Default Re=300 flow over a sphere
shailesh
Hi all,
I am simulating a Re=300 flow over a sphere. Acoording to the literature and previous numerical studies, wake at Re=300 is periodic and has shedded vortices..BUT i couldn't get any such periodicity...I read in some other papers..that at low reynolds numbers like..300..1000..flow is generally stable..and to start the vortex shedding..some perturbation has to be given..so I gave a perturbation..like multiplied the streamwise velocity in the upper half of sphere by 1.1 at some (only once) time step. Actually it seemed that it did have vortex shedding but only for some time..it couldnt be sustained and the flow is back to steady again..i am wondering what could be wrong..do i need to refine my grid more..??
regards shailesh
Old   August 14, 2003, 14:14
Default Re: Re=300 flow over a sphere
Jim Park
Difficulty in simulating shedding of vortices is I believe a classic problem.
If your numerical scheme (differencing or whatever) has excessive numerical dissipation, it can show up as what appears to be an artificially high viscosity - making the computational Reynolds number much less than the one intended. And, at a lower (computational) Re, the flow is non-shedding. Also, using upwind differencing with a mesh that's too coarse can have the same effect.
Take a look at some of the early (1960's!) papers by P. J. 'Pat' Roache (his book has a chapter on this stuff!) and C. W. (Tony) Hirt. Hirt's J. Comp. Physucs paper on 'Heuristic Stability Theory' shows the technique needed to analyze your algorithm.
It may be that you need only resolve your mesh (add more cells) to get a good simulation.
Good luck!
Old   August 15, 2003, 18:42
shailesh
Jim..thanks a lot!! for the informative comment..i was thinking along the same lines
Old   August 16, 2003, 06:47
versi
Simply refine your grid to see if unsteadiness occurs.
Flow over a sphere, wich model should i use dfmona CFX 4 June 13, 2010 18:32
Flow past a sphere Fabio FLUENT 23 December 18, 2009 16:32
flow across sphere at Re=10,000 raheelrasool Main CFD Forum 3 April 19, 2009 23:31
Modeling diffusion of cell (sphere) under flow Shel Main CFD Forum 0 August 22, 2005 16:26
3D sphere flow MH Kim Main CFD Forum 1 August 8, 2005 18:06
