Engine combustion related question
Old   August 12, 2003, 13:23
Default Engine combustion related question
Rag
I'm doing my Ph.D in " two stroke diesel engines with spark plug for efficient combustion'.
Is it possible to burn diesel by Injecting at lower pressure and igniting with spark plug
Old   August 12, 2003, 18:29
Default Re: Engine combustion related question
Dean
It is possible, but it may or may not be desirable. The efficiency of an ordinary diesel engine is partly due to its high compression ratio, so you will lose efficiency if you lower the combustion pressure. It would be surprising if there were not already some literature on this topic. SAE Transactions would be a good place to start looking.
analysis of internal combustion engine induction TOM FLUENT 5 August 29, 2011 06:20
question about modeling combustion xinhui zhang FLUENT 1 December 16, 2007 20:40
combustion in low heat rejection engine M.MANI Siemens 0 March 18, 2006 05:27
Using Fluent6.1 to model engine combustion Allanhill FLUENT 1 June 15, 2003 05:36
Question concerning about the flow simulation of a fan in an engine room. ghlee Main CFD Forum 3 October 21, 1998 08:05
