Turbulent viscosity ratio
Old   May 7, 2009, 19:25
Question Turbulent viscosity ratio
lost.identity is on a distinguished road
For a flow through a pipe what are the criteria in choosing the turbulent viscosity ratio, if one were to use the Spallart-Allmares turbulent model?
Thanks.
lost.identity is offline   Reply With Quote
Old   May 8, 2009, 00:38
Aroon
vishyaroon is on a distinguished road
Does SA model work well for internal flows? Just curious.
vishyaroon is offline   Reply With Quote
Old   May 11, 2009, 07:58
Not sure mate. I'm new to CFD. So far I can't say whether SA or k-epsilon works better. The problem is with k-epsilon (for the code I'm using) I need to have be careful of the first grid node of the wall (when using wall functions), with SA, apparently, this is not an issue.
Old   May 11, 2009, 12:57
N/A
harishg is on a distinguished road
It is also possible for you to convert your K-e model into low Re K-e model and you would be able to integrate your model through the viscous layer. Have a look at the book on Wilcox on how SA and K-e model performs for pipe flow.
harishg is offline   Reply With Quote
Old   May 11, 2009, 13:28
I think I tried that. You mean not to use wall functions with k-epsilon so that the first grid node has to be at a y+ of 100?
Old   May 11, 2009, 13:33
N/A
There are two versions of the k-e model that you can employ. in the first version you place your first grid point in the logarithmic layer (30 < y+<100) and use the so called high Re model. In the second version, you modify the turbulent viscosity with a damping term and integrate through the viscous wall layer. In this method the first grid node has to be below y+ <5.
If you use k-omega model you can integrate through the viscous layer without damping and sometimes obtain acceptable results.
Old   May 12, 2009, 07:38
cheers for that useful info.
i've decided to use SA model. I've been told this model will work whether you use wall functions or not.
btw, what's the closest you can have your first grid node from the wall? someone on this forum told me that for heat transfer problems the first grid node has to be within a y+ of much smaller than 1.
I did a grid independence study and found that when I had the first grid node at y+=1 and changed the vertical grid nodes it kept changing the solution (by solution I mean I measure the temperature, which changes slightly as I change the grid nodes). And when I had it at a very low y+ the change in solution was much small.
But I've been told by CFD code developer that it's stupid t have such a small y+.
Old   May 12, 2009, 13:24
N/A
Using yplus less than 1 ensures grid independent solution. Look for paper by Davidson and Peng - 1995 - Intl. Jou. of Num. Methods in Fluids. They discuss the grid refinement in the context of k-omega model but the same applies to your case too.
Old   May 13, 2009, 06:55
Sorry but I couldn't find that paper you mentioned. It's not even listed on Davidson's webpage. If it's possible could you let me know of the title please?
viscosity ratio
Turbulent viscosity ratio Balaji FLUENT 5 May 27, 2014 04:47
turbulent viscosity ratio James Willie FLUENT 1 June 21, 2005 04:35
On limiting to turbulent viscosity ratio! varghese FLUENT 2 November 15, 2003 09:56
Turbulent Viscosity Ratio xiang FLUENT 3 May 20, 2003 13:46
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
