May 5, 2009, 07:41 |
Gas Dynamic Problem
afifi
Dear All,
Do anyone here have experienced dealing with gas dynamic problems using CFD? Fyi, currently i'm doing some research using 'dynamic boundary conditions' for solving one of my test cases.. The objectives are to find the mass flow rate and time taken; 1. case 1: storage tank, there is a leak, gas coming out.. constant volume, what is the mass flow rate? parameters: Cd, pressure, density, area of leakage, lamda.. 2. case 2: pipe.. continous flow.. there is a leak.. how is the gas flow rate with continous varying volume.. same parameters as above.. 3. case 3: storage tank and pipe flow in and out of the tank.. there is a leak.. what is the mass flow rate? same parameters as above.. I have done with case 1.. success.. Any suggestion, which method and approach should i use for case study 2 and 3? What equation and formulas? Thank you in advance for all the help cheers!! afifi |
Problem with Dynamic Mesh and Fluent | Claude | FLUENT | 0 | December 12, 2006 07:14 |
Sod shock tube problem with real gas effects | ganesh | Main CFD Forum | 0 | October 17, 2006 02:22 |
problem about dynamic mesh of VOF model | whpsoft | FLUENT | 0 | September 9, 2005 00:06 |
Divergence in Dynamic Mesh Problem | James | FLUENT | 0 | September 28, 2004 09:43 |
Flow-Response Dynamic Coupled problem | wavefront | FLUENT | 2 | September 28, 2001 12:33 |
