May 4, 2009, 11:57 |
How to calculate Nusselt number
Sergey Malashenko
Rep Power: 17 |
Hello I need to calculate the Nusselt number for liquid sodium in a pipeline. Length of the pipeline is 3 meter. Diameter of the pipeline is 0.3 meter. Heat flux through outer surface of the pipeline is equal zero. Temperature on the right side and left side of the pipeline is 573 K and 773 K, respectively. Solution of the problem is free convective heat transfer.
Nu=/ is heat flux coefficient for liquid sodium at 673 K (average temperature) is effective heat flux coefficient including effect of free convective heat transfer. =Q/ST Q is heat flux through surface is the length S is cross sectional area of the pipe T is temperature difference (200 K) Which the surface have be used for calculation of Q? (the right side, the left side, the outer surface) How to calculate Nusselt number? TIA |
May 4, 2009, 14:13 |
Ahmed
Rep Power: 18 |
The Nu number, by definition, is a non dimensional heat transfer coefficient, in your case, you stated the outer surface of the pipe is adiabatic, so there is no heat transfer there.
Could you check your problem statement |
May 5, 2009, 01:55 |
Sergey Malashenko
Rep Power: 17 |
May 5, 2009, 21:38 |
#4 | |
Ahmed
Rep Power: 18 |
1- The sodium enters at 773K and leaves at 573K 2- Heat flux through outer surface is equal zero This is your problem statement, so what causes this temperature drop |
May 6, 2009, 01:57 |
Sergey Malashenko
Rep Power: 17 |
The pipe is insulated. There is boyuancy driven flow. On the left side and the right side only heat flux is set (temperature). Problem is solved into the pipe.
free convection, natural convection, nusselt number |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
how to calculate Nusselt number? | prayskyer | Main CFD Forum | 0 | June 17, 2006 20:57 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
