Beer - Foam formation
Old   May 4, 2009, 09:20
Default Beer - Foam formation
shogologo is on a distinguished road
Hi CFD users,
I would like to use CFD to predict foaming formation in beer.
Does anyone have such kind of experience in this?
How would you model fluid "Beer"?
I would think of it as a fluid with dispersed CO2, but I have some doubts regarding physical properties to be modeled (density, viscosity, ecc...)
Thanks a lot for your kind suggestion.
shogologo is offline   Reply With Quote
Old   May 5, 2009, 01:04
david.notay
gonski is on a distinguished road
I think SPH is the best choice for this kind of simulations. Try to search the works done by Paul cleary, Australia. I saw his results, but is not sure that they have been published or not. You may find some open sources on SPH.
I noticed that his movies are still available on a public place.
http://www.csiro.au/files/files/pers.asx
Cheers,
Gonski
gonski is offline   Reply With Quote
Old   May 5, 2009, 03:30
Thanks for your suggestion.
I've taken a look at Dr. Paul Cleary work.
What I can't understand is if it can be applied as a prediction tool (and integrated in a cfd code) or is simply a Maya plug-in for realistic effects...
Old   May 5, 2009, 03:46
david.notay
I mean SPH (a method) may be used for your project. I never use this method. Thus, you have to investigate it yourself, or get hints from someone else. If I remember it correctly, Paul also considered gas as particles in simulating beer flow in a cup. I always trace the works regarding SPH used for particle-fluid systems. But so far, there are not so many papers. This really means something. Maybe there are some uncertainties in handling particle-fluid or bubble-fluid interactions.
Good luck!
Gonski
Old   May 5, 2009, 06:13
Rui
Rui's Avatar
Rui Igreja
Rui is on a distinguished road
I don't know if this is going to help. But there's this in the Fluent web site:
Do the Bubbles in a Glass of Guinness Beer Go Up or Down?
http://www.fluent.com/about/news/pr/pr5.htm
http://www.fluent.com/about/news/pr/pr5.pdf
Rui
Rui is offline   Reply With Quote
Old   May 5, 2009, 11:08
Thaks Rui for your links.
I think these cases are "demonstrative" in order to get some small scale physical problems (bubbles - micron scale) and are sure interesting - so to speak maybe are developed for "commercial" purposes...
I think that foam formation could be related to this scale phenomena (bubbles rising) and hope to find a sort of model of prediction.
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
