Harpoon import issue (origin?)
Old   April 27, 2009, 18:58
Default Harpoon import issue (origin?)
CSN
LiveandLetDrive is on a distinguished road
This is version 3.4(c)
When I import my geometry from an STL file (short cylinder) into Harpoon for meshing, the location of the origin seems to have no relationship to the geometry. In the Solidworks model the origin is dead center of the part, in Harpoon it is somewhere outside of it, in line with the flat side of the cylinder but otherwise off in space. Rotating the geometry just confuses things as the mix/max extents don't seem to rotate with the geometry (as demonstrated by snapping the far-field to the min/max). Any attempt to translate the geometry toward the <0,0,0> point temporarily seems to work but the origin moves again when the view is refreshed and re-clipped.
What is the deal? Am I going to have to deal with this arbitrary offset or is there some way to make the origin sit in the middle of the geometry where it belongs? Thanks for your help, I'm out of ideas!
(Also, does anyone else find that they sometimes can and sometimes can't drag a refinement zone's corner, even when "interactive" is checked?)
LiveandLetDrive is offline   Reply With Quote
Old   April 27, 2009, 21:02
CSN
In other news, every time I create a cylinder as a refinement zone, it appears in different and inconsistent ways. To try it out I created 6 cylinders in a row with exactly the SAME settings (even clicked the same points to initialize the shape and didn't rotate the view at all). Despite this I got cylinders in 3 different orientations, none of them where they were supposed to be. It's like the coordinate system is rotating itself for no apparent reason?
This software is so full of things like this, it is ridiculous. I know the obvious response is to contact Sharc's support, which I will be doing, but wanted to see if anyone's had similar problems with Harpoon.
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Gambit IGES import numeration issue Nicolas Meynet FLUENT 1 October 7, 2006 13:44
HARPOON Evaluation Tang Main CFD Forum 12 April 27, 2006 15:18
Coordinate of axis origin Tang FLUENT 0 October 4, 2004 17:38
import mesh problem Wendy CFX 2 February 6, 2002 06:39
