NACA0012 gird generator
Old   April 27, 2009, 00:55
Default NACA0012 gird generator
Prashanth
Prashanth is on a distinguished road
I would like to know where I will be able to find a grid generator code for the NACA 0012 airfoil. Thank you...
Prashanth
Prashanth is offline   Reply With Quote
Old   April 27, 2009, 00:59
N/A
harishg is on a distinguished road
I guess you need to be specific on what kind of grid you need ?
harishg is offline   Reply With Quote
Old   April 27, 2009, 01:54
Praveen. C
praveen is on a distinguished road
For unstructured grids, look at bamg, gmsh, triangle (shewchuck), delaundo.
Dont know any for structured grids.
praveen is offline   Reply With Quote
Old   April 27, 2009, 02:41
Prashanth
I was looking for structured O grids
Old   April 27, 2009, 07:34
Anon
technophobe is on a distinguished road
There's an analytical function for the thickness of a NACA00XX airfoil.
The upper surface of the airfoil is given by:
upper(I) = thick*5.*(0.2969*sqrt(x(I)) - 0.1260*x(I) - 0.3516*x(I)^2 + 0.2843*x(I)^3 - 0.1015*x(I)^4 )
Where 'thick' is the airfoil thickness - 0.12 in your case. x(I) is the distance along the normalised chord (i.e. x/c) at the I'th node. The NACA0012 is symmetric so simply reflect across the x-axis and you've got your foil.
Note that this gives a shape function that doesn't close at the trailing edge. This is a feature of the NACA analytical functions. In my own work this doesn't cause any problems but you can simply set the thickness to be zero at the trailing edge to close the foil if you need to. The camber is zero for this 'foil.
Hope this helps,
T
technophobe is offline   Reply With Quote
Old   May 1, 2009, 05:20
Praveen. C
There is an O grid generator here
http://www.ae.gatech.edu/people/lsankar/AE6022/
Air-Jet Vortex Generator, request for some papers ROOZBEH FLUENT 0 July 12, 2008 11:28
Air-Jet Vortex Generator, request for some papers ROOZBEH Main CFD Forum 0 July 12, 2008 11:27
3D NACA0012 with vortex generator Franny Main CFD Forum 3 April 10, 2007 19:09
grid generator Edwin Munts Main CFD Forum 2 December 4, 2000 15:54
Grid generator for structured grids Tore Myhrvold Main CFD Forum 5 January 21, 1999 09:09
