oxygen flow rate
Old   July 31, 2003, 08:38
Default oxygen flow rate
lwhan
would some body tell me how much flow rate is safe in the pipe?
Old   July 31, 2003, 12:03
Default Re: oxygen flow rate
lwhan
Old   August 4, 2003, 14:39
Alton Reich, PE
Iwhan,
By "safe" I'm going to assume that you are looking at the question from a structural integrity stand point. That is actually not a question for CFD folks. The structural integrity of piping systems is governed by the ASME Pressure Vessel and Piping Code (adopted as a standard in Taiwan).
For air piping, you will probably want ASME B31.3 which governs process piping. In some special cases the ASME Boiler and Pressure Vessel Code, Section 3 or Section 8, should be used. If you're unclear which code to use, consult an expert.
Regards, Alton
How can apply mass flow rate boundary condition? Sima Phoenics 1 December 1, 2007 19:55
Inlet and outlet flow rate Neser CFX 1 March 2, 2004 17:02
Mass flow rate Neser CFX 4 February 14, 2004 01:27
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 05:47
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 03:19
