July 30, 2003, 13:55 |
Angular momentum
I have done some steady viscous calculations of a turbine stage with a cell centered multigrid code using Jameson scheme and Baldwin Lomax turbulence model. After doing these calculations, I have found the power produced by the rotor with an enthalpy balance, that is:
Power=(ro cx h)_in - (ro cx h)_out Then I have calculated it using the angular momentum, that is: Power=(ro cx r cth w)_in -(ro cx r cth w)_out with : ro = density cx = axial velocity h = total enthalpy r = radius cth = tangential velocity w = angular speed of the rotor _in = inlet of the rotor _out= outlet of the rotor I have obtained different values (differences are greater than 1%); then I have calculated, and included in the balance, the torque due to the endwall boundaries and I have also changed the grid but ... nothing. Can you help me? Best regards, Nicola |
July 30, 2003, 14:28 |
Re: Angular momentum
Try repeating your prediction with a coarser grid and/or a finer grid. I suspect you will find that you have simply derived an indirect way of demonstrating numerical error in you solution (probably not particually useful one because of postive errors cancelling negative ones). A code can only strictly conserve a small number of physical quantities, the rest have to suffer the effects of truncation errors.
July 31, 2003, 12:09 |
Since you have a mass flow term in your calculations, the level of mass flow convergence enters into this. How well is your solution converged? Also, as you have a density term, you have to consider how accurately density is calculated. Your final comment regarding torque brings in another source of error.
July 31, 2003, 13:31 |
Mass flow error is 0.4% between inlet and outlet sections and I think solution is converged.
>Your final comment regarding torque brings in another source of error Can you explain? |
Angular momentum flux through faceZone | askjak | OpenFOAM Programming & Development | 1 | March 5, 2010 15:42 |
Derivation of Momentum Equation in Integral Form | Demonwolf | Main CFD Forum | 2 | October 29, 2009 20:53 |
angular momentum in swirling flows | Roberto | CFX | 3 | October 22, 2007 08:05 |
angular momentum with swirling flow | Roberto | FLUENT | 0 | October 20, 2007 12:18 |
Angular momentum conservation? | Barry | Main CFD Forum | 19 | April 11, 2002 11:37 |
