TURBULENT boundary layer over a cube
Old   April 22, 2009, 17:27
Question TURBULENT boundary layer over a cube
CFDstudent is on a distinguished road
I am very very new to CFD and am embarking upon a class project.
Basically I am simulating a turbulent boundary layer flow over a roughness element. I am using Fluent and will compare my results to some experiments. In this comparative experiments, this was scenario was carried out in an open channel with water.
To make things simple I am putting my 2-D roughness in pipe and imposing the "water surface" as a symmetry axis. Is is acceptable? Also, I want to use a Re number similar to what was used in the experiments (around 5,300) however this Re number is based on momentum thickness. How feasible is it for me in my case to evoke the condition of similarity? My Re number would be based on my pipe diameter....or should I do something else?
thank you in advance for your help!
CFDstudent is offline   Reply With Quote
boundary layer, cube, roughness, turbulence model
Turbulent boundary layer on a flat plate seb62 OpenFOAM Running, Solving & CFD 0 January 16, 2009 10:33
Errors in Gambit for boundary layer mesh Mike Spears FLUENT 0 June 23, 2005 12:34
Boundary Layer Meshing of a nosecone Chris FLUENT 1 March 15, 2005 13:42
Wall turbulence, viscosity, boundary layer Patrick Godon Main CFD Forum 1 November 5, 2003 16:39
flat plate boundary layer data Ekachai Juntasaro Main CFD Forum 3 March 14, 2001 00:18
