Compressible laminar boundary layer
Old   July 21, 2003, 14:55
Default Compressible laminar boundary layer
Pierre Ricco
I wrote this code which gives the disturbances of velocity and temperature on top of the steady flow, which is a steady laminar boundary layer with no pressure gradient (basically Blasius but with energy equation coupled). The code is parabolic and I am marching downstream from initial profiles. Variables are complex (also the BC) in the free-stream.
Everything is fine for Mach number smaller than 2.5, for higher ones the code blows up. Do you please have any suggestions for parabolic system with COMPLEX BC?
Thanx a lot!
Boundary Layer Question scottneh STAR-CCM+ 3 September 30, 2010 15:21
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Laminar or tubulent Boundary layer? Rodrigo Madariaga FLUENT 1 January 23, 2003 21:41
help for Gambit: 2 edges + 1 boundary layer Peter FLUENT 0 August 9, 2002 20:41
boundary layer of a flat-plate dwi s Main CFD Forum 1 November 9, 2000 02:45
