how to analyze the temporal dissipation and dispersion errors? |
Edison
Rep Power: 17 ![]() |
how to analyze the dissipation and dispersion errors generated by temporal discretisation?
If von Neumann analysis is used, for multistep schemes, finally a polynomial is obtained. There are one or more roots of such polynomial. Then how to analyze the dissipation and dispersion errors? Thank you. |
N/A
Look for papers by Tam et. al on dispersion relation preserving schemes. He has given a detailed analysis on the analysis of temporal discretization errors. Also Hirsch has a section on the same topic in vol. 1
Edison
thank you so much
