Check the skewnesses of your face meshes and make sure the face mesh sizes are not to
Old   April 13, 2009, 18:27
Default Check the skewnesses of your face meshes and make sure the face mesh sizes are not to
sophie
sophie-l is on a distinguished road
hi,
i am trying to mesh a big cylinder with an other small one that is tangentiel to the first. I can mesh the big one without problems, but when i try to mesh the small one the following message of error is given by gambit:
Check the skewnesses of your face meshes and make sure the face mesh sizes are not too large in areas of samll gaps
what should i do?
thanks
sophie
sophie-l is offline   Reply With Quote
Old   April 13, 2009, 20:16
LSF
LSF is on a distinguished road
What you need to do is make sure that the size difference between the two meshes is similar at the points where they meet.
Large size differences between the two meshes will cause cells to be skewed, resulting in that error.
It can help if you mesh all edges first - at the point where the smaller cylinder joins the large one set the node spacing to be very similar.
You can then mesh the faces (and then volumes, if you have)
LSF is offline   Reply With Quote
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 08:06
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 05:49
Fluent 6.3.16 + Polyehdral Meshes Carlos FLUENT 3 March 15, 2007 04:09
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
