Validation case for fluid/solid interaction
Old   July 11, 2003, 16:39
Default Validation case for fluid/solid interaction
Raj
Hi, I am looking for a test case for invisid-fluid/linear-elastic-solid interaction which has analytical solution. It should be primarily concerned about accuray and conservation of data transfer between fluid & solid solvers.
Thanks in advance!
Regards, Raj
Comparison of axisymmetric case, Starccm+ and OpenFOAM linnemann OpenFOAM Running, Solving & CFD 12 June 16, 2011 06:43
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
Need help to open an OpenFoam case with Paraviw aaurouss OpenFOAM 2 July 6, 2009 14:18
Roe Scheme; Shock Boundary layer Interaction Mohammad Kermani Main CFD Forum 5 December 20, 1999 16:44
Heat Transfer Validation test case Chris Whitney Main CFD Forum 1 July 21, 1999 15:36
