Analytical Solution of 1D Convection Diffusion Eq.
Old   July 10, 2003, 16:15
Default Analytical Solution of 1D Convection Diffusion Eq.
Suman Kumar
I am looking for reference on analytical solution for one dimensional steady-state convection-diffusion equation.
Regards,
SK.
Old   July 11, 2003, 01:27
Default Re: Analytical Solution of 1D Convection Diffusion
Markus Lummer
Try
www.math.umn.edu/~olver/appl_/npd.pdf
Regards,
Markus
Old   July 14, 2003, 04:55
K.M. BAZEETH AHAMED
If i have understood ur question in right sense. It is available in most of the heat and mass transfer textbooks. (I understood that u need a solution for a 1D mass transfer problem by diffusion and by convection)
Old   July 14, 2003, 13:37
Suman Kumar
Thanks you very much for your response ! I am looking for the method of ananytical solution of STEADY ONE-DIMENSIONAL CONVECTION-DIFFUSION EQUATION. It is the Equation-5.4 Section-5.2 at Page-80 of " NUMERICAL HEAT TRANSFER AND FLUID FLOW" by PATANKAR. The exact analytical solution is given in the same reference in Section-5.2.3 at Page-85. I am looking for the reference book which describes the method for getting above mentioned solution.
Regards, SK.
Old   July 14, 2003, 14:53
ag
If it's the equation
dc/dt + c(dc/dx) = nu*d2c/dx2
then the solution can be found using the Cole-Hopf transformation as outlined in "Linear and Nonlinear Waves" by G. B. Whitham, chap. 4. The procedure is remarkably straightforward and consists of transforming the equation to remove the nonlinear term.
(Sorry, I don't have Patankar's book on hand)
Old   July 14, 2003, 20:21
ag
I should have added that the steady state solution can be found by looking at the behavior of the full solution for large time.
Old   July 15, 2003, 04:11
K.M. BAZEETH AHAMED
hi as i dont have the book specified by u. i was not able to refer it. still i belive that i can help u in getting the solution if i know the nature of the problem exactly.Is it a heat transfer problem? or mass transfer problem? or mixed one? What is the equation and varaiables involved and the boundary conditions? u can mail me to kmbahamed@rediffmail.com
Old   July 15, 2003, 15:05
MT
for the following equation U(d(phi)/dx) = nu*d2(phi)/dx2 Phi being any variable, you can use solution to second order ODE with constant coefficients (Ref: Kreyszig, Engineering Math.). It will have exp(+/-) function as the basis solutions, constants will be determined from BC. If I recall correctly, that's what is described in Patankar's book. Note: ag gave a better (i.e. more general) answer to convection-diffusion equation in this message thread
Oscillating Cylinder in Parallel Flow: Analytical Solution startingcfd Main CFD Forum 7 March 23, 2012 06:49
Linear analytical solution oto the 2D free sloshing water surface elevation bearcat Main CFD Forum 7 August 5, 2011 21:13
Analytical solution to validate code lost.identity Main CFD Forum 2 July 22, 2010 20:38
convection, diffusion, advection, dispersion Lam Main CFD Forum 7 May 18, 2007 13:04
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
