Energy Spectrum !!!
Like Tree41Likes
Old   April 20, 2014, 23:58
Huang Xianbei
huangxianbei is on a distinguished road
Originally Posted by FMDenaro View Post
just consider a 3d Cartesian mesh and (j,k) some fixed positions. This is some lines of my Matlab code for the energy spectrum
% ____________ E_uu (stream-wise)______________
% ff is a dump array for using the FFT of the field u(i,j,k)
for i = 1:np+1, ff(i) = u(i,j,k); end
% Discrete transform: computation of the Fourier coefficient
c=fft(ff,np); for q = 1:np, c(q)=c(q)/np; end
% Computation of the modulus squared. Cycle for all the wavenumbers
for q=1:np, cu(q,k)=c(q)*conj(c(q)); end
Then, you must simply plot your power spectrum.
Generally, the computed spectrum are also computed along the whole homogeneous directions (e.g. for all the k) and then averaged to have a statistically meaning.
Hi,Filippo
Sorry for the second reply.I followed your advice, here is my code in matlab
clear all;
[x y z Ux Uy Uz]=textread('U_constantPlane.raw','%f%f%f%f%f%f','headerlines',2);
 N=32768;
 Lz=6.28;
 kz=(2*pi*(1:256)/Lz);
 kzz=round(kz);
 w=reshape(Uz,256,128);
 wk=fft(w);
for i = 1:256,
    for j=1:128,
    wk(i,j)=wk(i,j)/N;
    end
end
for i = 1:256,
    for j=1:128,
    R(i,j,kzz)=wk(i,j)*conj(wk(i,j));
    end
end
for j=1:128,
    E(kzz)=0.5.*R(j,j,kzz(j))*4*pi.*kzz(j)^2;
end
plot(kzz,E(kzz))
I have the velocity on a plane and the points are 256*128, so I turned the U into a 256*128 matrix. By doing the whole program, the result is zero! I don't know why, could you please help me?
shuige likes this.
huangxianbei is offline   Reply With Quote
Old   April 21, 2014, 04:17
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by huangxianbei View Post
Hi,Filippo
I think the third line should be: cu(q)=c(q)*conj(c(q))
As known, the velocity spectrum tensor is
phi[i,j](k)=cu(k),the energy spectrum is integrated to
E(k)=1/2*cu(k)*dS(k)
where S(k) is the sphere's surface area with radius mag(k)
is this means to calculate E(k)=1/2*cu(k)*4*pi*k^2?
yes, the second integer k is just becasue I stored in a matrix for all the points along the z-axis
FMDenaro is offline   Reply With Quote
Old   April 21, 2014, 04:33
Huang Xianbei
Hi,Filippo,
Thank you for your reply, could you please have a look at my previous reply for the code?
Also, I tried another case which only contains 1 line of velocity in z direction.The result is still incorrect
clear all;
[z Ux Uy Uz]=textread('Zleft_U.xy','%f%f%f%f');
 N=128;
 Lz=6.28;
 kz=(1:N)*2*pi/Lz;
 k=round(kz);
 c=fft(Uz,128);
  for q = 1:N,
      c(q)=c(q)/N;
  end
  for q=1:N,
      cu(q)=c(q)*conj(c(q));
  end
  %up to now, the velocity-spectrum is obtained,however, the q~=k,
  %how to match them?
  for q=1:N,
      E(k)=0.5*cu(q)*4*pi*k.^2;
  end
  plot(k,E(k))
Old   April 21, 2014, 05:13
Huang Xianbei
I managed to match them with this:
E=0.5.*cu.*4*pi.*k.^2;
Again,the result is incorrect
Old   April 21, 2014, 05:18
Hi,Filippo
clear all;
 N=32768;
 Lz=6.28;
 kzz=round(kz);
 wk=fft(w);
for i = 1:256,
    for j=1:128,
    wk(i,j)=wk(i,j)/N;
    end
end
for i = 1:256,
    for j=1:128,
    end
end
for j=1:128,
end
plot(kzz,E(kzz))
wk=fft(w)
this way, w is a matrix???
Old   April 21, 2014, 05:31
Huang Xianbei
wk=fft(w)
yes,because z values are ranged in a periodic way(256 values one loop), so 32768 values corresponding to 128 loops, representing the whole value on a plane. Is this resonable?
I'm now confused about the wavanumber k, is this write as:
(1:N)*2*pi/Lz
each one is connected to a cu value in order?
Old   April 21, 2014, 05:40
(1:N)*2*pi/Lz
therefore, fft(w) returns the Fourier transform of each column of the matrix and store in wc.
Anyway, I suggest checking for a simple test: generate a sin(k*x) function (try for some k value) and store in a vector, after doing the fft plot the spectrum and check if the energy density is located at the right frequency
Old   April 21, 2014, 05:56
Huang Xianbei
All right, I'll try it. Another question is still needed to be solved as I have asked:
what's definition formula of k?
2*pi*n/Lz?
Best reguards
Old   April 26, 2014, 10:00
Huang Xianbei
Originally Posted by ehsankf View Post
modes should change from -N/2:N/2.
This should be -N/2:N/2-1 for an odd N.
Old   April 29, 2014, 16:40
Amjad
Amjad Asad is on a distinguished road
hello,
could i get ur code pls, my Email is amjadju@yahoo.com
thanks
Amjad Asad is offline   Reply With Quote
Old   April 29, 2014, 22:42
Huang Xianbei
Originally Posted by Amjad Asad View Post
hello,
thanks
you can find it in http://www.cfd-online.com/Forums/mai...tml#post488460
Old   July 8, 2014, 02:10
SHEIKH NASIRUDDIN
nasir.iitd is on a distinguished road
Dear Harishg,
I 'm also facing the same problem and want to plot energy spectra using matlab. Can you send me the code you have used. My e-mail is:nasir.iitd@gmail.com
Your help is highly appreciated.
nasiruddin.
nasir.iitd is offline   Reply With Quote
Old   October 27, 2014, 20:42
Purvi
p3vdim is on a distinguished road
Can I get the code for energy spectrum?
p3vdim is offline   Reply With Quote
Old   October 27, 2014, 21:08
Huang Xianbei
hello,
thanks
Sorry that I just check my thread. Do u still need it?
Huang Xianbei
Yes, most of my code is in this thread, if you need, I'll send you a .m file with email
Old   October 27, 2014, 21:30
Purvi
Yes, that will be great and if you can send me understanding of it too!!!
Thanks
Purvi
my email address is : p3vdim@yahoo.co.in
Old   October 28, 2014, 00:53
Huang Xianbei
Thanks
Purvi
I have sent you the code. The explaination is not so much for the limited time, hoping this can help you.
Xianbei
Old   October 28, 2014, 05:34
chandra shekhar pant
chandra shekhar pant is on a distinguished road
Please send it to me also ..
chandukec@gmail.com
chandra shekhar pant is offline   Reply With Quote
Old   October 29, 2014, 15:33
Leon is on a distinguished road
Would you mind sending me the code as well? bmeyer907@gmail.com
Thx in advance!
Leon is offline   Reply With Quote
Old   October 29, 2014, 18:55
Default Energy spectra
  #60
Purvi
Hi Guys,
I am also having problems with plotting energy spectrum. Could somebody plz send me the code.
My email address is : p3vdim@yahoo.co.in
Thanks in advance!!
energy spectrum, fft
turbulent energy spectrum problem cfd.newbie Main CFD Forum 6 September 24, 2015 17:13
turbulent energy spectrum cfd.newbie Siemens 1 June 20, 2008 00:48
turbulent energy spectrum cfd.newbie FLUENT 0 June 18, 2008 19:34
LES correlation and turbulent energy spectrum Fabian Main CFD Forum 4 October 18, 2005 03:04
Energy Spectrum Emad Khalifa Main CFD Forum 3 June 30, 2003 17:03
