How to solve a Poisson equation with only Neumann boundaries?
Old   March 31, 2009, 14:14
Default How to solve a Poisson equation with only Neumann boundaries?
mbgnfrx2 is on a distinguished road
I need to solve a pressure Poisson equation with only Nuemann boundaries with F.D. method. How we can get the unique results without introducing any errors into?
Many thanks in advance!
mbgnfrx2 is offline   Reply With Quote
Old   March 31, 2009, 21:46
gory is on a distinguished road
Specify a pressure value (any value) at just one point (anywhere) on the boundary.
gory is offline   Reply With Quote
Old   April 1, 2009, 04:23
But if we set up a reference point at the boundary, certain error will introduced. any possibility we do not do that?
Cheers!
Old   April 1, 2009, 10:56
What kind of error? There is no unique exact solution to this problem, not just for discretely but analytically: the solution is unique only up to an additive constant.
Old   April 1, 2009, 12:12
yes, that is the thing. If we set one of the point on the boundary as reference point, which is Dirichlet bounday. But how we can make sure it is also satisfying the Nuemann boundary condition? If it is not, error on the boundary will be introduced.
Cheers!
Old   April 2, 2009, 03:56
Rami Ben-Zvi
Rami is on a distinguished road
Cheers!
You may prescribe the reference pressure value at any point, not necessarily on the boundary.
Rami is offline   Reply With Quote
Old   April 2, 2009, 05:01
MrFluent
mr_fluent is on a distinguished road
When you construct your matrix A.
Make Albnd = 0, and do not add its contribution to Ap (or diagonal element).
Imagine that your Ap (diagonal element) is like this
Ap = -Sum (Al)
To get Ap you usually do Ap = Ap - Albnd
Src = Src + albnd * phi (if phi was fixed value).
Instead now you do not modify Src. Do not modify Ap, just make Albnd = 0.
solve matrix.
You get some solution, pick a point from these Phi you just calculated. Lets say iref.
phi_ref = Phi[ iref ] ;
For all
Phi = Phi_from_matrix - phi_ref.
Thats all. Painless and simple.
mr_fluent is offline   Reply With Quote
Singular Linear System - Pressure Poisson Equation Allan Main CFD Forum 11 March 17, 2011 10:39
Poisson Equation with Neumann bc Beginner Main CFD Forum 0 September 6, 2007 10:18
Poisson equation with Neumann boundary conditions cregeo Main CFD Forum 8 July 26, 2004 05:58
How to solve Poisson equation in CFX 4? windhair CFX 3 January 27, 2004 22:09
Solve Poisson equation Linfeng BI Main CFD Forum 4 November 21, 2002 00:46
