blade interface for unsteady computation
Old   June 11, 2003, 04:27
Default blade interface for unsteady computation
wang
Hi all,
i have a question about the blade interface. Normally, the numbers of stator and rotor blades in turbomachinery are not equal. To conduct an unsteady simulation, the blade interface should be matched to each other. I've heard about some scaling methods to solve this problem. Can anyone tell me in detail or give me some references?
I thank you very much in advance.
wang
Old   June 11, 2003, 11:44
Default Re: blade interface for unsteady computation
centaur_ks
there are couple of techniques for this kind of problems. one is developed by Erdos J.I. refer to his AIAA paper. The otherone which will i think be suitable for your case is developed by Rai M. M. you can refer to AIAA journal for his paper
J-
Old   June 11, 2003, 13:02
A.S.
Look for J.D. Dentons and W.N. Dawes paper in Journal of turbomachines particularly 1992.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
blade interface for unsteady computation wang CFX 1 June 11, 2003 19:33
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
