May 26, 2003, 22:51 |
Help on premixed combustion heat
I try to simulate 2-d premixed combustion of methane and air in porous media burner with a laminar flame. Overall reaction model(ch4+2o2--->co2+2h2o) based on Arrhenius reaction laws was employed.
When using the reaction model, one should have the exact velues of some related parameters,eg. the pre-exponential factor,heat of reaction per unit mass reactant and activation energy. After refering to some publications, I was confuseded completely because no any two papers have the same values. What are the exact velues of the parameters on earth? What should i do? Thanks to any response! Seaspace |
May 27, 2003, 04:38 |
Re: Help on premixed combustion heat
Hi, The heat of reaction shouldn't be a problem, but I don't think there is such a thing as 'exact' pre-exponential factors and activation energy if you are looking at the overall reaction. As you are describing several hundred elementary reactions in one step, your two parameters can only cover a narrow range of conditions (if they manage that) depending on your application. I would recommend starting with a set of parameters from literature and see if the results make sense. Look for articles by Zhou, Pereira, Bouma, De Goey, Hsu, Ellzey, Viskanta or Echigo. Hope that helps.
Volker |
May 27, 2003, 05:28 |
HI,
as Volker said, the 'Activation energy' is always the same,preexponential changes. To check it, bets would be to start with literature values and check the flame velocity S_L under normal condition if you get about the right velocity. Generally most of the codes takes the values for global reactions from Westbrook: @Article{Westbrook, author = "Westbrook, Ch.K., Dryer,F.L.,", title = "Chemical Kinetic Modeling of Hydrocarbon Combustion", journal = "Prog. Energy Combustion Science", year = 1984, volume = 10, pages = {1--57} } or: "On Simplified Reaction Mechanisms for the Oxidation of Hydrocarbon Fuels in Flames by C. K. Westbrook and F. T. Dryer", Combustion Science and Technology, 1985, Vol.43, pp. 333-339. Are you sure, that single step global methane will do in porus burner? no catalysis? matej |
Modelling of premixed combustion in a burner rig | ThomasS | FLUENT | 12 | September 7, 2018 13:07 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Diesel combustion simulation ( Heat release rate) | venkatesh | Siemens | 2 | April 29, 2009 07:38 |
Non-adiabatic Premixed combustion through scriptin | Mahesh | FLUENT | 0 | March 31, 2007 08:19 |
