Hi! To solve a potential flow past an aerofoil, which is suitable method-finite difference method,finite volume method or finite element method? Also what kind of grid should be generated?I am writing my own code
You should use a boundary element method (e.g. the panel method) since then you only require points on the boundary of the domain - because you are solving Laplace's equation the solution anywhere in the domain can be obtained solely from the boundary data.
Panel Method or boundary element method is more popular than other methods for solving Full Potential Equation.
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
flow around a cylinder | pXYZ | Main CFD Forum | 14 | July 25, 2011 10:05 |
flow past a sphere | CHEN | Main CFD Forum | 1 | January 30, 2010 02:12 |
Flow past orifice | aurel | Main CFD Forum | 0 | January 27, 2009 06:46 |
Unsteady simulation of flow past wheel | Tom | FLUENT | 8 | January 18, 2006 10:54 |
