Modelling a propeller
Old   May 15, 2003, 15:17
Default Modelling a propeller
amorriison
How do CFD programs model a propeller?
Various methods - pressure increasing disk - to CFDing the propeller blade itself?
Old   May 16, 2003, 05:17
Default Re: Modelling a propeller
Holidays
It depends what you want to do. In most cases one will model the propeller per se and set a multi-frame of reference case. With CFX I have seen modelled the full hull, the propeller and the free surface; this is important as for boats the interaction between propeller and hull can be fundamental (or propeller and pod).
In some cases, say a big water treatment tank or a mixing vessel maybe, you may represent the stirring effect of blades via a source term, although this might not always work well, eg if the baldes are close to walls or if the blades occupy a significant volume in the vessel etc.
Modelling an accelerating propeller siw CFX 2 September 21, 2011 10:53
Modelling a propeller tomg STAR-CCM+ 4 April 28, 2011 18:22
Modelling airplane fuselage with propeller thepassenger FLUENT 1 November 8, 2010 23:19
modelling a propeller vass FLUENT 0 March 28, 2006 15:24
Modelling a propeller with actuator disc Jean-Marie FLUENT 1 July 23, 2003 16:05
