May 9, 2003, 22:57 |
Lax-Friedrichs flux in H-J equations
I want to use the Lax-Friedrichs flux to solve the Hamilton-Jacobi equations. I can't understand the meaning of the flux. For example, there is one expresssion,alpha(u+,u-)=max(abs(H1(u,v))), u(-[A,B],v(-[C,D]. [A,B] is the value range for u+ and u-,and [C,D] is the value range for v+ and v-. The problem is, I can't understand the meaning of [A,B] and [C,D]. u+ and u- denote the two upwind discretization. Thanks! Reference 1. S.Osher and C.W. Shu, High-order essentially nonoscillatory schemes fro Hamilton-Jacobi equations. J. Numer. Anal., v28,1991,ppp.907-922
May 10, 2003, 09:17 |
Re: Lax-Friedrichs flux in H-J equations
Hi there,
Yo should have a look at the following paper: techreports.larc.nasa.gov/icase/1997/icase-1997-65.pdf It is a good introduction to the ENO scheme and will (I think the information you require is there) help you unerstand the concepts in your question. John. |
Guide: Writing Equations in LaTeX on the CFD Online Forums | pete | Site Help, Feedback & Discussions | 27 | May 19, 2022 03:19 |
Flux splitting | Dr B.M. Smith (Smith) | OpenFOAM Running, Solving & CFD | 19 | January 9, 2013 04:07 |
Problem setting with chtmultiregionFoam | Antonin | OpenFOAM | 10 | April 24, 2012 09:50 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
Lax Friedrichs Flux Splitting | srikant srinivasan | Main CFD Forum | 1 | February 16, 2001 09:12 |
