Convergence Speed
Old   May 5, 2003, 15:43
Default Convergence Speed
Maciej Matyka
Hello, I have done three different solvers: SIMPLE,SIMPLER and Vorticity-Stream approach to 2D incompressible... How to test convergence speed? When I am calculating simple test case for Driven-Cavity method (non-dimensional variables, Re=100,200,300 etc.) convergence speed is approximately the same for three methods. For some cases SIMPLER converges faster than SIMPLE, but vorticity-stream approach is between them.For convergence I am calculating (at the end of iteration step) a maximum value of difference between old and new computed velocity (both for u and v component). I am ok with that?Best Regards,Maciej Matyka
Old   June 12, 2003, 13:20
Default Re: Convergence Speed
Sebastien Perron
To measure convergence, you could also take the norm of the residuals. Personally, I always use both (variation and residuals).
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Convergence speed in free surface simulations Chebeba CFX 13 July 23, 2009 14:08
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
speed up convergence for drag Aymeric CFX 1 March 8, 2006 19:56
