Data transfer
Old   May 4, 2003, 11:33
Default Data transfer
H. P. LIU
Now, I want to transfer the data between PC and Unix system,butI don't know how to establish the data transfer and data connection between my local PC (Windows operating system) and Cray UNICOS system although I have successfully transfered the data between alpha workstation and CRAY supercomputing system. Thank for your help.
Old   May 5, 2003, 03:54
Default Re: Data transfer
Rami
Try FTP.
Old   May 5, 2003, 06:06
H. P. LIU
Thank for your reply.
In deed, I have used ftp command to transfer the data between alpha workstation and Cray UNICOS system. At the same, I also can transfer the data from my local PC to alpha workstation. but I want to establish the direct connection between my local PC and remote CRAY system. I know my IP address of local PC and can login to CRAY system, I use the Telnet, ftp command in CRAY to connect my login local PC, but it doesn't work, Is it the firewall problem? Best regards,
Old   May 6, 2003, 06:22
j
You can make a direcotry in the workstation and define it as a net neighbour of the PC. Then, any file you put in this directory can be read directly in the PC.
Old   May 6, 2003, 06:59
j
Old   May 19, 2003, 11:47
H. P. LIU
Thank for your help In fact, I can directly visit my all files in the shared directory in my alpha workstation defined by a net neighbour of the PC, as you have mentioned in this response. However, I want to establish the same visiting method, i.e. the directory under CRAY SYSTEM can appear in my local PC as a shared directory. What can I do it? Thanks!
[OpenFOAM] Cell Data to Point Data Issues mcintoshjamie ParaView 2 November 19, 2009 04:55
Data Transfer - Polyflow to Fluent to Abaqus Bob Carson FLUENT 0 March 27, 2007 10:31
Saving particle (DPM) data to file? Philip FLUENT 2 June 12, 2006 02:41
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
additional variable mass transfer in CFX5.6 john CFX 1 February 14, 2004 01:30
