AutoCad to CFD
Old   April 21, 2003, 11:26
Default AutoCad to CFD
Eep Saeful
Dear Sir/Mam Is the CFD can import AutoCad drawing, and how to do it? If I want to use two difference material, eq: coating powder and air. Is CFD can use it.? Because right now i study about Pneumatic Conveying and i analyze fluid flow in ejector..
Thank and Regrads
Eep
Old   April 22, 2003, 03:47
Default Re: AutoCad to CFD
Anton Lyaskin
You can export your AutoCAD drawing as IGES or as STL file. Most CFD codes can import them. For me IGES is good for 2D drawings and STL for 3D surfaces.
Regards, Anton
Old   April 23, 2003, 00:36
Selina Tracy
Could you explain why you prefer STL over IGES for 3D. IGES can have beautiful NURBS for 3D. Does STL have such a feature? -Selina Tracy
Old   April 29, 2003, 03:12
Anton Lyaskin
It's only my personal opinion. The problem is not in the IGES format itself but in the way AutoCAD exports it and in the way the software I use read it. For this particular combination of codes I often get badly defined surfaces (gaps, holes and etc.) with IGES.
Old   May 1, 2003, 19:32
Daniel
Hi, Anton,
Can be the exported file used in CFX 5.5?
Thanks
Old   May 2, 2003, 08:42
Holidays
That is true Anton, depending on the CAD from which it is created IGES files can be a right pain to fix.
Old   May 5, 2003, 04:51
Anton Lyaskin
Probably the problem is that I'm using an old version of AutoCAD - R14. But for me it's more convenient to use IGES for keypoints an edges, from wich I can built a multi-block mesh, and STL for surfaces for automatic mesh generation. Both IGES and STL from AutoCAD can't give me surfaces wich I can use "as is", but IGES gives problems wich require plenty of "hand work" for fixing and STL gives problems wich can be fixed with automatic remeshing (I'm using STAR-CD with ProAM).
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 15:01
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
