COMPARISON BETWEEN VARIOUS CFD SIMULATION APPROACHS OF REACTIVE TURBULENT FLOWS
Old   February 25, 1999, 12:08
Default COMPARISON BETWEEN VARIOUS CFD SIMULATION APPROACHS OF REACTIVE TURBULENT FLOWS
mounir
I am looking for works on reactive turbulent flows in which there is comparison between two or more differents approachs:
- Monté-Carlo /PDF (problility density functions) - Beta function/mixture fraction - Eddy contact/multi-fluids - DNS (Direct Numerical Simulation)
a lot of thanks mounir
Old   February 25, 1999, 13:49
Default Re: COMPARISON BETWEEN VARIOUS CFD SIMULATION APPROACHS OF REACTIVE TURBULENT FLOWS
John C. Chien
Could you give us some background information about each simulation method for turbulent reacting flows? And also why they are being pursued in so many different ways. Is this field almost hopeless?
Old   February 26, 1999, 00:33
fred
One the one reasons for using particle based method is the simplicity of modelling several types of particles which interacts together trough collisions. One can easily understand that it is very simple to model a chemical reaction with that type of approach (particle 1+particle 2 -> particle 3).
One other reason is the simplicity of the update algorithm which is linear. The approach is different from PDE solvers where you try to solve directly NS equations. In a particle method,you can come back to NS trough the update equation. Actually, one industrial code (see www.exa.com) uses this method for external and internal subsonic aerodynamics. It is a very promising field but unfortunately unknown for a majority of CFD people (as it is based on statiscal mechanics and gas kinetic theory)...
Fred
Fred
Old   March 1, 1999, 07:06
Roland Bender
i think we have to made a distinction between different particle methods!
For turbulent reactive flows you can solve the transport equation for the joint probability density function (PDF) of velocity and composition. The PDF can be expressed as a sum of delta-peaks, which can said to be stochastic particles. The evolution of this particles can be calculated. By averaging them you can get the means and then moments of the PDF.
The great advantage of this method is, that reaction appears in closed form.
About the Lattice-Boltzmann-Method i don't know anything. But after a short look on www.exxa.com, i think its a different method
Greets
Old   March 3, 1999, 13:07
Ayhan Temel
I'm a mechanical engineer. I want to improve myself in this area
Is it a difficult & challengin CFD simulation case Sarwa FLUENT 2 November 29, 2006 13:56
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 21:33
CFD Symposium (Call for Papers) Chris R. Kleijn Main CFD Forum 0 October 5, 1998 11:25
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 8, 1998 09:19
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 3, 1998 09:45
