March 5, 2003, 17:11 |
Discharge pump flow
A shipper pump has 2 MOV's at suction and discharge. The Suction valve is open and discharge valve close. the discharge valve will be open when the pump start by sequincing time. Now, WHAT IF THE PUMP START AND THE VALVE NOT OPEN FULLY, IS THERE ANY POSSIBIITY TO TRIP THE PUMP BECUSE THE BACK PRESSURE? IF YES, CAN WE START ANOTHER PUMP AS SUCTION IN SERIES, IS IT WILL EFFECT THE PRESSURE AND PREVENT THE TRIP OF THE FIRST PUMP? THE OTHER PUMP WILL BE AS SUCTION OF FIRFT ONE.
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Problem with centrifugal pump calculation | Michiel | Main CFD Forum | 2 | June 17, 2012 21:32 |
Fully Developed Flow in Star-cd | SMM | STAR-CD | 0 | September 5, 2011 22:08 |
pump prevalence at low mass flow rates | Caterina | Main CFD Forum | 0 | January 8, 2011 16:05 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
