discontinuous solutions
Old   March 4, 2003, 15:08
Default discontinuous solutions
dav
what is the meaning of discontinuous solutions mathematically???
Old   March 5, 2003, 10:50
Default Re: discontinuous solutions
P. Birken
I just assume that you refer to discontinuous solutions to PDEs. These are thought of as existing in an integral sense. You can integrate discontinous functions and using the Green-Gauss theorem you can transform integrals of derivatives over a domain to an integral over the boundary of the domain of the function (not the derivative). You also have to keep in mind, that solutions are not discontinious in time, but only in space.
Hope that helped a bit,
Philipp
Old   March 5, 2003, 15:39
dav
i.e. right it is for PDEs. could you please explain to me this:
....that solutions are not discontinious in time, but only in space.
ALSO, do you agree with this
discontinuous solutions means we've to think in shock, contact and rarefactions, etc.
now where is the weak solutions come here???
Old   March 5, 2003, 17:53
ag
The term weak solution is a mathematical invention that describes a solution which is not continuously differentiable over the entire domain. In a classical sense solutions to PDES must possess derivatives at all points in the domain in order to satisfy the PDE. However, if we cast the equation into an integral form we find that some discontinuous solutions can be found that satisfy the integral form and also satisfy the differential form in a restricted sense, i.e. piecewise continuous. Solutions which satisfy this requirement are referred to as weak solutions. In fluid mechanics, the governing PDES for inviscid flow possess weak solutions, in that solutions can be found that satisfy the integral form in a global sense and the differential form in a piecewise sense. The physical interpretation of these solutions is that these discontinuities are shock waves, and to fully specify a solution in a local sense we have to impose additional constraints in the form of jump conditions across the shock. At least that's what I remember from advanced math.
Old   March 6, 2003, 06:00
P. Birken
Thinking of discontinuous solutions as shocks and such is correct.
A shock is for example a discontinuouty in space. At one point in space, you have one value, then you cross the shock and at the next point you have a value which is much smaller or much bigger.
The shock may travel in space with time, it can move (eg. a moving weather front). But it cannot jump in space with time (the weather front does simply dissappear not appear elsewhere the next moment). This is meant with: the solution is discontinuous in space, but not in time.
If you want more details about weak solutions than ag provided, I advise to look into Randall LeVeque, Numerical methods for conservation laws.
Yours,
Philipp
Old   March 7, 2003, 18:29
Ananda Himansu
In an N-dimensional spacetime manifold, a shock wave is a discontinuity in the "solution", with the discontinuity occurring across an (N-1)-dimensional hypersurface S. The hypersurface S is never purely spatial (because of the finite speed of signals), and so there is never a purely temporal discontinuity. However, in a sense that is symmetric with respect to space and time, the "solution" can be said to be discontinuous in BOTH space AND time. For example, if one takes a constant-time slice (hyperplane), the solution appears as a discontinuity in a spatial traverse (the "support" of the discontinuity is the trace of S in the constant-time hyperplane). On the other hand, if one takes a slice in which some spatial coordinate remains constant, and time is allowed to vary, the solution appears as a discontinuity in a temporal traverse. The exception to the latter rule is the case of a stationary shock, when every such slice of spacetime containing the time axis (except for the special one containing the stationary flat shock) has no discontinuities in the solution, whereas every constant-time slice does exhibit the shock. These matters can also be understood from the geometry of the solution surface in the (N+1)-dimensional manifold formed by adding the solution dimension to spacetime.
To put it more simply, imagine the following: plot the readings of a pressure probe at a fixed location in a shock tube, against a time axis, during an experiment in which a shock travels through the tube. A plot of pressure versus time will show a discontinuity at the time value that the shock passes the probe. Voila! A shock discontinuity in the time direction!
Old   March 10, 2003, 06:49
P. Birken
Well, if you look at the solution pointwise (slice in t-direction), then you have of course a discontinuouty in time. What I meant was that the function u(x;t) as a function of x changes continuously with time in the function space you are working with (L2, H1, whatever), taking the appropriate norm. This corresponds more to the physical/engineering sense of the solution.
Old   March 10, 2003, 17:47
Ananda Himansu
Philipp,
I thought that your response of 5 Mar, and ag's response of the same day, were both excellent in explaining to the questioner, dav, what the mathematical meaning of "discontinuous solutions" is. The one small point that I wished to make in my response of 7 Mar is that the difference between time and space for shock waves is more subtle than apparent at first blush.
It is true, and I did admit this on 7 Mar, that the time coordinate is special, by comparison with the spatial coordinates. Stationary shock waves are possible, for which the "supporting" hypersurface S has a normal vector which is always perpendicular to the time direction. Whereas, a discontinuity for which the supporting hypersurface has a normal vector which points in the time direction is not possible (due to the finite propagation speed of signals).
That having been said, I submit that the geometry of the hypersurface S is rather more symmetric with respect to space and time than your responses of 6 Mar and 10 Mar would imply. As I understand it, your explanation of "discontinuity with respect to space and not time" of 6 Mar, amounts to saying that the spatial location x_s of the shock wave is continuous with respect to time. This does not actually refer to whether the shock itself is a discontinuity with respect to space or time or both. As you and I have agreed upon, the shock is a discontinuity with respect to both space and time. I say that a counterpart of your statement of 6 Mar can be made, which shows the symmetry with respect to space and time. One can equally well say that the temporal location t_s of the shock wave is continuous with respect to those directions of space into which the shock propagates. Look at the one-spatial-dimensional case: The shock passes the pressure probe located at some x, at a time t_s. The shock must then pass the pressure probe located at an infinitesimally further position x+dx at an infinitesimally later time t_s+dt, which can be phrased in the epsilon-delta language of limits and continuity.
As regards your different reasoning of 10 Mar, I must say that taking an L2 norm or other measure, amounts to a spatial averaging or a spatial integration. Such a measure is of course insensitive to the values of the solution on a set of measure zero, such as the support of the discontinuity. The counterpart of your statement about time continuity of spatial integration measures may be made, which shows the symmetry with respect to space and time. Considering, for simplicity, again the case of a traveling 1D shock wave, I imagine that one could define a measure of the solution that, at a given spatial location x, involves the integral with respect to time of the square of the solution. Such a measure would, I imagine, display the same kind of continuity with respect to space, as does the L2 norm with respect to time.
The word "solution" as used in the PDE and CFD literature can mean one of several things, depending on the context: (a) the value of the dependent field u at a point in spacetime, (b) the aggregate of the values of u at every point in its spacetime domain of definition, (c) the aggregate of the values of u at every point of a constant-time hyperplane in spacetime, or (d) the aggregate of the limiting values (as t tends to infinity), if such exist, at every point of a constant-time(t) hyperplane in spacetime (the "steady-state" solution).
Old   March 11, 2003, 08:40
P. Birken
Mh, there is not much to add to your answer. You are completely right and my use of the L2 norm was pretty useless and I see now, that the asymmetry between space and time is not as strong as I thought. Thanks!
Using your solution concept c), I think that the following statement makes sense:
Take the solution u_t(x) (a function in the space of piecewise continuous functions over x). This solution varies continuously with t in the space of piecewise continuous functions over x with the maximum norm.
It corresponds exactly to "the spatial location x_s of the shock wave is continuous with respect to time".
Old   March 11, 2003, 13:59
Ananda Himansu
Philipp,
You are quite welcome. Glad I was able to communicate effectively enough, even though unable to use much mathematical symbolism in this message-board medium.
Thank you for clarifying the connection between your responses of 6 Mar and 10 Mar. I agree with your statement that a solution u_t(x) (in the sense (c)) that lives in the space of functions that are piecewise continuous wrt x, can in some sense be said to be a continuous function of time t, since the discontinuity itself is accounted for in the aggregation of values over x, and the remaining properties such as norm and discontinuity location vary continuously with t.
Our discussion has brought to light that a symmetric statement can also be made in which the roles of t and x are reversed. Thank you for a stimulating discussion.
Old   March 12, 2003, 05:47
  #11
P. Birken
The pleasure was on my side!
Yours,
Philipp
Old   March 13, 2003, 15:28
  #12
dav
I've enjoyed both sides but as an applied mathematician I enjoy the application of the mathematical analysis to the physical and engineering side.
simply think in this way; does discontinuous solutions exist to a case like compressible two-phase flow?
so what do you think??
Old   March 17, 2003, 06:41
  #13
P. Birken
I'm actually not familiar with two-phase flows and how the solutions look like. In pricipal, the existence of discontinuous solutions depends on your model. If you use the Euler-equations (hyperbolic) as a basis, then discontinuous solutions will exist. If you use Navier-Stokes (parabolic), diffusion smooths out the discontinuouties.
On the other hand, this might look different on the numerical level, if you use a finite volume scheme or discontinuous Galerkin, where you allow discontinuouties over cell edges in the discretization.
Old   March 28, 2003, 06:51
  #14
R. Andom.
"Stationary shock waves are possible, for which the
"supporting" hypersurface S has a normal vector which is always perpendicular to the time direction. Whereas, a discontinuity for which the supporting hypersurface has a normal vector which points in the time direction is not possible (due to the finite propagation speed of signals".
Would it not be better to say "for which the
"supporting" hypersurface S has a normal component of the vector which is always perpendicular to the time direction"?? Would the normal vector to the discontinuity not have a component in the time direction?
Old   March 28, 2003, 06:53
  #15
R. Andom.
The above respoinse was to the following message:
Ananda Himansu , Mon, 10 Mar 2003, 2:47 p.m
Sorry about the confusion.
Old   March 31, 2003, 18:07
  #16
Ananda Himansu
Andom,
A general admissible discontinuity has a "supporting" hypersurface "S", the normal vector "n" to which will indeed always have a non-zero component in the spatial direction. And yes, any such surface-normal vector will in general have a non-zero temporal component. For the SPECIAL CASE of a STATIONARY DISCONTINUITY, however, the temporal component of the normal vector will be zero. Hence my statement that for a stationary shock-wave, the normal vector is perpendicular to the time direction, i.e., is purely spatial in direction.
Briefly put: An S for which n is purely temporal will NOT support a discontinuity in the solution (the solution would exhibit a simultaneous jump at all spatial locations). However, an S for which n is purely spatial is quite capable of supporting a discontinuity in the solution (it would be a stationary shock wave or contact discontinuity). The n for a general shock always has a non-zero spatial component, and also has a temporal component which is zero only for stationary shocks. Other than this space-time asymmetry, solution discontinuities are more symmetric with respect to space and time than one might guess.
multiple solutions using Fluent Hanjie Lee FLUENT 3 August 15, 2006 18:21
Analytical flow solutions Antonio Main CFD Forum 0 December 14, 2005 16:43
Analytical flow solutions Antonio Main CFD Forum 0 November 15, 2005 18:47
Blasius Solutions Devin FLUENT 0 October 22, 2003 14:04
Exact solutions zhor Main CFD Forum 4 May 13, 2001 12:26
