MAC method
Old   February 27, 2003, 16:30
Default MAC method
Farid Babadi
I need a free source code of MAC Method for modeling free surface wavy falling flow. Please e-mail me the source code or the link.
Thanks a lot Farid
Old   March 2, 2003, 18:26
Default Re: MAC method
Danny Tandra
CFDLIB http://gnarly.lanl.gov/secondlevel/codes/cfdlib.htm
Danny Tandra
Old   March 4, 2003, 04:03
kenn
MAC was excellent, but outdated. Volume of Fluid is better. and Arbitrary Lagarangian Euler could better.
all these above three teckniques are explicit
if you really are a serious researcher, I'll recommend you to use Level Set Method, which is implicit.
Old   March 4, 2003, 05:38
Default references
kenn
1. volume of fluid JCP 39, 201-225(1981), by C.W.Hirt
2. ALE JCP 14, 227-253(1974), by C.W.Hirt
3. Level Set "Level Set Methods and fast Marching Methods" by J.A.Sethian, 2nd edition cambridge 1999
MAC was explained together with first appearance of projection method in a report by Harlow.
Old   March 4, 2003, 10:16
Jim Park
"all these above three teckniques are explicit"
Actually all three are semi-implicit. By this I mean that, for each time step, the momentum equations are advanced in time explicitly. Then the pressure (continuity) eqaution is time advanced implicitly. Finally the advanced-time pressure is used for the final continuity-satisfying corrections to the velocities.
So you wind up iterating only the pressure equation. But the allowable time step is limited by the explicit treatment of momentum at the beginning of each cycle.
It's often a useful trade-out if you really want to see a transient solution. And that's where Harlow et al started.
MAC method solve for pressure at boundry Ron Main CFD Forum 2 January 28, 2006 03:14
MAC method shvia Main CFD Forum 1 September 20, 2004 10:07
Pressure boundary conditions in MAC method Ravi Main CFD Forum 4 January 21, 2000 14:50
use of MAC method to solve sloshing problem. S.R.SAHI Main CFD Forum 1 April 15, 1999 23:28
Marker And Cell method (MAC) Albert Badal Main CFD Forum 0 February 27, 1999 20:53
