boundary layers and k-w model
Old   February 14, 2003, 09:08
Default boundary layers and k-w model
paul
Hi all,
I'm trying to create a compressible turbulent boundary layer profile to fit experimental data from a supersonic flat plate test case.
The reason I need an analytical profile is to act as an inlet to the computational domain, as the experimental data doesn't go into the viscous sublayer.
I am using the Wilcox k-w turbulence model so therefore require profiles not only for the velocity, temperature, density etc.. but also for the k (turbulent kinetic energy) and omega (specific dissipation rate) from the viscous sublayer through to the boundary layer edge.
The velocity, temperature and density profiles seem okay but I am having trouble finding references on how to specify the k and omega profiles for compressible flat plate cases.
I'd have thought that this is something turbulence modellers do on a regular basis so can any of you guys let me know of any good references that specify exactly how to create the k and omega throughout the whole boundary layer. (I have the Wilcox book)
or alternatively what you turbulence modellers usually use in a case like this.
Also, can anybody tell me what Wilcox uses to create the initial boundary layer profile in the EDDYBL code?
Thanks in advance for any help and advice
Paul
Old   December 8, 2009, 03:01
Default EDDYBL code
Rungroj W.
Sammy is on a distinguished road
Hi paul
Do you have EDDYBL code? Can you send
it to me via e-mail?
Thank you in advance.
Sammy
Sammy is offline   Reply With Quote
Boundary layers in Gambit Ian FLUENT 3 March 3, 2012 10:54
High-Re / Boundary Layers alex_rubel OpenFOAM Running, Solving & CFD 0 March 31, 2011 00:26
SST model and boundary layers Rodrigo Basniak CFX 7 March 27, 2008 15:19
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
Gambit 2 Boundary Layers An Modh Coinniolach FLUENT 2 January 30, 2002 12:54
