February 12, 2003, 19:43 |
Approximate Mixing due to Natural Convection
I'm looking at a process involving surface reactions (combustion/gasification) on walls in large reactors. The mixing and fluid flow in the reactor may be governed by natural convection which is most likely time-periodic. Unfortunately, I don't think I can simulate the transient behaviour due to computational limitations - its 3D, >10m size^3 and I have a minimum of 7 species and the residence time in the reactor is large. In order to approximate this situation I've been looking at using a steady state model, and modifying diffusion parameters to "appproximate" the mixing effect of the natural convection. Has anybody tried this? How did you go about it? Was it successful etc??? I imagine that in the limit of very high diffusion I'll get a CSTR type model from the CFD, while with the standard steady model I'll get a lot less mixing. Probably the natural convection mixing and mass transport - if I could simulate it - would lie between these two extremes. So I thought I'd look at the extremes and see what I get. Anybody got any ideas, suggestions or inisghts which might be helpful? Anything appreciated Greg |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 10:26 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 05:58 |
Mixing By Natural Convection Processes | Greg Perkins | FLUENT | 0 | February 12, 2003 19:40 |
Heat of mixing - natural convection | Andre | Main CFD Forum | 0 | May 10, 2000 06:42 |
Heat of mixing - natural convection | Andre | FLUENT | 0 | May 10, 2000 06:40 |
