Simple question
Old   February 12, 2003, 18:12
Default Simple question
Robi
I have written a code for compressible (varable density, ideal gas for example) flow in a pipe using SIMPLE. When the condition is isothermal I observe no problem. When I include the energy equation in the model (inlet temperature is fixed and I set the pipe wall temperature equal to Ta<T_inlet) all my problems start. The steady state solution is correct while in the transient part I observe negative pressure, back flow. Is is because of initial condition? I am sure the energy code is correct. The major problem is for the transient part. Can anyone help me with this? Is there any free code for such a simple problem?
Many many thanks for your help.
Old   February 13, 2003, 01:27
Default Re: Simple question
Reader
Where is your simple question?
Old   February 13, 2003, 01:51
Robi
Sorry it seems part of the message was somehow omitted.
So here is the question one more time:
I have written a code for compressible (variable density, ideal gas for example) flow in a pipe using SIMPLE. When the condition is isothermal I observe no problem. When I include the energy equation in the model (inlet temperature is fixed and I set the pipe wall temperature equal to Ta< T_inlet) in the transient result I observe negative pressure (with respect to outlet pressure) and some back flow. my question: Do you think the back flow and negative pressure is due to my incorrect (incompatible) boundary condition? Is there any free code similar to this problem so I can verify or compare the results? Many many thanks for your help.
Simple Outlet Question m.nichols19 OpenFOAM 3 June 25, 2010 02:44
Simple Question Regarding Symmetry Planes Atella CFX 3 April 11, 2010 07:44
Simple Question Regarding Symmetry Planes Atella Main CFD Forum 0 April 9, 2010 11:58
Question of Anil Date's SIMPLE method universez Main CFD Forum 0 November 18, 2009 21:12
Simple Question Regarding Continuity Closure RC FLUENT 2 March 25, 2004 06:30
