linear triangular element
Old   February 8, 2003, 14:29
Default linear triangular element
hani
for linear triangular element, the linear inerpolation using triangle with three nodes at its corners gives a constant derivitive. I wonder if some one aware about any remedial modification that can result with a derivative that is dependent on the location within the triangle element. The elemnet is still to be the same. I appreciate any reply
Old   February 11, 2003, 01:45
Default Re: linear triangular element
Selina Tracy
I do not know enough on this matter.
However, I've heard that it always gives constant stress (structural analysis) inside the triangle unless we are using quad-element.
I just want to check if that is true or not.
-Selina
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
autoPatch error, mesh quality related...? Alexvader OpenFOAM 0 October 6, 2011 18:57
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
Fifth-order triangular element Jonas Holdeman Main CFD Forum 0 June 16, 2004 13:34
Shape Functions for Curved 2-D Triangular Element Abhijit Tilak Main CFD Forum 0 November 30, 2003 14:14
