Pressure correction question - Please help!
Old   February 5, 2003, 01:24
Default Pressure correction question - Please help!
Barry
Dear friends
I have 1-dimensional mesh with colocated variable arrangement. The mesh represents a pipe section.
The inlet velocity is fixed and the outlet velocity gradient is zero. The pressure at the outlet boundary is constant.
My questions: What must be the boundary conditions for the pressure correction eqn? (SIMPLE algorithm)
Also, how is the BC for the pressure correction eqn implemented? How do I ensure that the pressure at the outlet boundary does not change (we calculate cell values)? Therefore how do I ensure that the pressure correction will be zero at the outlet boundary face?
Typically how many iterations of the momentum solution for every pressure correction solution and how many global iterations required? (just a ball park figure will do)
Thank you Barry
Old   February 5, 2003, 01:27
Barry
Forgot to say:
The flow is steady, laminar and incompressible.
Divergence detected in AMG solver: pressure correction emlejeen FLUENT 5 December 15, 2016 00:47
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
basic question for pressure BC vivien OpenFOAM 0 November 23, 2009 06:01
pressure correction and absolure pressure George Main CFD Forum 5 March 22, 2005 07:10
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
