Nonlinear PDE
Old   December 18, 2002, 07:40
Default Nonlinear PDE
eyesfront
Dear all, how to solve a nonlinear PDE which is fourth order in space(one dimension r in cylindrical coordinate) and first order in time. I have got the initial configuration, four other boundary conditons.
Thanks in advance
Old   December 18, 2002, 09:22
Default Re: Nonlinear PDE
Praveen
There are no general methods for the solution of pde. You will have to give complete details of the problem, pde, ic, bc, and geometry before anybody can help you.
Old   December 18, 2002, 14:35
xueying
You can low the order by introducing 3 more unknowns, and then solve by Newton method
Old   December 19, 2002, 05:11
Default Nonlinear PDE in more detail
eyesfront
Thanks for your reply. The PDE is like the following
-dh/dt=h^3*(1/r^3*dh/dr-1/r^2*d^2h/dr^2+2/r*d^3h/dr^3+d^4h/dr^4+h^2*dh/dt(-1/r^2*dh/dr+1/r*d^2/dr^2+d^3/dr^3)
at t=0, initial configuraton h(r) given at r=0, dh/dr=0 and d^3h/dr^3 =0 at r=2, dh/dr=1 and d^2/dr^2=1
It seems impossilbe to lower the order of derivatives by introducing three other unknown since this is a nonlinear PDE.
I look forward to your further comments.
Old   December 19, 2002, 05:12
versi
If it looks like a diffusion ( 4th order dissipation) , it can be solved by implicit schemes such as backward Euler and a central scheme for spatial 4th order terms.
Old   December 19, 2002, 16:20
Dr Strangelove
If you've got an initial condition that is sufficiently differentiable, then you can march forward in time pretty easily, even using something as simple as Backward Euler.
Many books on numerical methods and on CFD can provide you with more details on methods that will probably work with your equation.
Algorithm for coupled pde with all flux boundary conditions benk Main CFD Forum 3 December 28, 2010 06:09
Could someone suggest simple (nonlinear) solver Bren Main CFD Forum 10 March 7, 2009 07:36
nonlinear instability JackMM Main CFD Forum 6 October 5, 2007 08:20
Problem with Nonlinear k-epsilon model bylin FLUENT 4 November 23, 2003 22:45
Stability for Nonlinear Numerical Scheme Guo Main CFD Forum 3 February 12, 2001 13:21
